1. PaulQ's Avatar
    I have a new LG G3. Love it. Except I have a question to determine if I have a lemon or not.
    When I unlock the phone, the home screen comes up and for just a second, the left side of the screen is lit up brighter than the rest of the screen. It's sort of white. It then fades to show the beautiful home screen (well, I might be biased). Is this normal?
    It's only when I use the pattern lock. Which I like.
    Can you check yours?
    (hope I am explaining myself clearly)
    Thanks!
    12-15-2014 09:35 PM
  2. PaulQ's Avatar
    In case someone else has this problem, I'll answer my own question. After actually exchanging the phone and hours of "play" with it, I discovered the glitch. It only happens when you are using the "dew drops" or "raindrops" (I don't know what it's called and my phone isn't with me now) pattern lock. If you use the basic or balloons one, it doesn't happen. So, it's some sort of flaw in the system but you can avoid it by not using that pattern lock. Unfortunately, it's a really cool pattern. There you have it!
    belodion likes this.
    01-03-2015 12:23 AM
  1. Note 4 screen flickers and half the screen is shaded
    By Morganz187 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 01-06-2015, 03:50 PM
  2. Do you wear your 360 when u sleep?
    By icellphones32 in forum Moto 360
    Last Post: 12-17-2014, 01:39 PM
  3. Is the next Note 4 upgrade 5.0?
    By PlanetPluto7 in forum Samsung Galaxy Note 4
    Last Post: 12-15-2014, 11:39 PM
  4. How do you make a sd folder in gallery?
    By Derrick Cytryn in forum Ask a Question
    Last Post: 12-15-2014, 09:37 PM
  5. Why is the send button hidden when texting in Horizontal mode?
    By AccuzzamEnomis in forum Ask a Question
    Last Post: 12-15-2014, 09:27 PM
Tags for this Thread
