lg g3 lollipop in Romania is less changed than expected
ksm09
112
Just received the update last night, no so many changes i would expected. Some apps already had that "material design" like youtube, calendar, magazin play etc. Differences are in some visual effects, the multitasking, in apps info when checking ram... Notifications (in lock screen and notif bar...) and seems that's all. I'm missing something here ? Maybe is the optimus ui, or lg skin the cause ?? Pure android is more changed ?
Posted from Lg G3
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,389
254
83
Yes, the differences are greater on my Nexus 5 than on my G3.
deutsh
10
Let me tell you a thing ...... LG G3 has already the material design at 4.4.2 ,hence.....it's change in 5 is little
belodion
Moderator
Jun 10, 2014
39,389
254
83
What about battery? It seems like it drains to fast :(
Posted from Lg G3
Battery on my G3 has been worse than it used to be for several weeks. I don't know why.
So far, after just a few days, I'm not aware that Android 5.0 has made a difference.
ksm09
112
You think so ? 20 min sot and still 100%, i know it is overcharged a bit at 100, hope it's a callibration issue and not smth worse...
Posted from Lg G3
beezlebubz
113
Posted from Lg G3
Did they remove the stock email app as well or do you still have it? Not the gmail one.
AlfieBriggs
79
LG have a skinned version of Android, so much was never going to change as they haven't updated their skin only the version of Android.
Posted via my amazing Note 4 paired with my Moto360
ksm09
112
And, the g3 is not so laggy, it's not at all with a few changes :) i bet it beats your note 4 :) btw, how you deal with battery ? Post me a few ss if you want :)
Posted from Lg G3
beezlebubz
113
Posted from Lg G3
I forgot to ask, is screenshot gone in lollipop using qmemo or what its called?
beezlebubz
113
Screenshot is there, qmemo also...
Posted from Lg G3
But is screenshot still in the qmemo app as a feature? I heard for some people the lollipop update removed screenshot from the qmemo app etc. So it only left you to manual press back buttons to take the screen shot.
19escape20
