1. Shirrazz's Avatar
    I love my G3 and have had no negative issues with the new Android, except for this one. When I receive a call, the bottom half of the screen is blank/black. I'm able to answer and end a call only because I know where the icons are, they still work but I just can't see them. Upon ending the call, the whole screen comes back. It's only on incoming calls that I've had this issue (although, I don't use too many apps so don't know if it's occurring elsewhere). I do not root my devices.
    Any ideas how to fix this?
    Thanks!
    02-21-2015 12:46 PM
  2. Android_Ayub's Avatar
    Hello Shriraz! My name is Android_Ayub and i am 14 years of age. Try to cache partition wipe your device and try to learn how to root it. If that doesn't work than i recommend either taking it to a technician repair shop to see the internal motherboard and to see if the screen or motherboard should be replaced
    02-21-2015 02:02 PM
  3. Shirrazz's Avatar
    Thanks, Android_Ayub, but your solutions are all a bit drastic. I'll live with this issue since it's such a small one.
    02-21-2015 02:37 PM
  1. Replies: 1
    Last Post: 02-21-2015, 07:06 PM
  2. Replies: 2
    Last Post: 02-21-2015, 03:09 PM
  3. Replies: 1
    Last Post: 02-21-2015, 02:04 PM
  4. How do I delete Facbook notifications on my LG Android?
    Last Post: 02-21-2015, 01:08 PM
  5. Replies: 0
    Last Post: 02-21-2015, 12:30 PM
