Why won't my LG G3 charge or recognize USB?
viljami323
Active member
Feb 16, 2015
39
Why my LG G3 wont charge or recognize USB
Why my LG G3 wont charge or recognize USB if i plug it in to my pc?
yes i can charge it, but i need to power off it and then plug charger and after that it will charge
but i wont charge if its tuned on
what is problem?
is it something with software? software bug?
I use Nokia charger.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,384
250
83
Are you sure that the USB lead is in good condition and that the USB ports are clean and undamaged?
durango992007
213
8
Re: Why my LG G3 wont charge or recognize USB
Have you tried using your LG cable? I remember my old razr maxx wouldn't be recognized by my computer unless I had the Motorola cable. It would charge, but transferring files between the 2 was out of the question. Also, make sure your usb cable is in good condition and the port on your phone is clean and free of dust and debris.
viljami323
Active member
Feb 16, 2015
39
I dont have orginal lg G3 USB cable where i can get one?
Reason why i need working usb is
I want Dowgrade to android 4.4 and root it
Genuine LG EU Travel Charger Adapter G3 G2 Nexus 5 G Pro2 USB Cable Original | eBay
So guys do you think this will fix problem
Well it works on my lenovo A806
and also!
Phone won't charge or recognize USB connection unless battery removed
The only thing that gets it to charge is if I remove the battery, connect the charger, insert the battery. After it runs on its charging fine.
any ideas?
clandestine1234
I am another LG G3 user with this identical problem suddenly. Phone worked fine for years, but now it shows no signs of recognizing when the usb has been plugged in to either the wall or to a computer. No charging, and no notifications etc. In order to charge, I must turn the phone off, then plug it in and wait for it to fully charge before turning back on.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
anyone solved ?
Welcome to Android Central! In your PM to me, you said "My LG G3 doing nothing. no led no charge no turn on no reset nothing." If you've already tried a different charging cable/plug and left it plugged into a wall outlet overnight, then it's probably either a dead battery or a dead motherboard. Have you already tried replacing the battery?
