1. jakeyjunkie's Avatar
    I've been having problems with volume. You might be having the same problem or might be able to help me. The problem has been too annoying.
    My 32gb LG G3 D855 just keeps on lowering the volume by itself. My touch feedback sound is on and just a notch away from full volume. However, the sound is unstable in that it just lowers itself. I keep checking the setting but the level is just the same and not changing.
    For example, one series of tapping on the screen has the expected volume. After some time, the next series of tapping on the screen has their sound feedback dropped by itself to very low. It is fluctuating and unstable.
    Just now, I turned everything to full volume and tested things out. To my surprise, even my notification and ringtone volumes are also unstable. They go very low to hear at one point, then get back to being loud again. All by themselves. It came to a point where my ringtone is at maximum level, then when I tested it (tapped at the adjuster), the sound was very low. Then after testing again, it goes back to the intended full volume.
    In summary, the volume just drops down by itself, then gets back to the expected level, then drops down again. Very unstable.
    Are you having the same issue?
    03-19-2015 12:00 AM
  2. xocomaox's Avatar
    I have not seen this happen before. When the volume level goes down, does the slider actually change position? Or does the sound just get quieter?
    I hate to say this, but perform a full factory reset on the thing to rule out this being a software problem. If that doesn't work, I think it's malfunctioning hardware and should be repaired (under warranty, hopefully).
    03-19-2015 07:29 AM
  3. jakeyjunkie's Avatar
    Hello! The second is correct. When the volume goes down, it just goes quieter even if the slider is at full volume. In the sound settings, I tapped on the slider's head positioned at full volume and the sound is still quieter. Give it some time and it goes back to the expected sound again.
    A full factory reset might really be in order but I'm hoping that there could be other solutions. Thanks!
    03-19-2015 12:19 PM
  4. matty032's Avatar
    I have seen the same thing happened a time or two on mine.
    03-20-2015 03:38 PM
  5. Tcbemis's Avatar
    Since I've updated to Lollipop and done the FR, I'm noticing my notifications are weird. Sometimes very loud, sometimes normal... Sometimes I can barely hear them. I'm referring to both the native text app and Hangouts as well. I'm using sounds from the phone, not downloaded from Zedge, etc.
    Anyone else having this problem? (yes, I've restarted)
    I'd tried posting that the other day, but it didn't work.
    I've done a factory reset. Two actually.
    03-20-2015 04:01 PM
  6. vahernandez's Avatar
    My device is having the same issue. I have a G3 (D851) with the lollipop update. I noticed the fluctuating volume levels while streaming
    Tidal and using the LG HBS750 bluetooth headset. I assumed this was going to require a master reset but I wanted to wait and see if any other solutions found the light of day.
    04-19-2015 03:18 PM
  7. elduderino619's Avatar
    I am having the same issue on my HTC one m9. I also found the power button doesn't respond promptly now and will go into a safe mood by itself when it does reboot. I have had the same pair of headphones (w/ a mic) and this phone for almost a year now and it just started today. Pretty frustrating.
    08-27-2015 04:52 PM
  8. Ulonda Jaskula's Avatar
    I am having the same issue... Did you ever find a resolution??? ������������������
    09-02-2015 04:10 PM
  9. Johnny Martinez2's Avatar
    Im having a problem with my bluetooth earphones, they tend to lower in volume and i check the music volume only to find out its the same. The volume in the settings isn't changing, only on the bluetooth earphones. For every 8 seconds they decrease in volume but raise back to the normal volume the next second.
    09-25-2016 01:11 PM
  10. RolandStone's Avatar
    Its still happening across many models and makes of phones, Nexus, HTC, Samsung, and its still happening on Oreo 8.1.0. It happens on Bluetooth and with headphones. It happens on Google Play and Spotify. And its not just the media volume. Ring volume also gets silenced randomly. Somebody help please! Volume Lock apps don't prevent it, they struggle to restore after the momentary random drops. Clearing cache doesn't help. Factory reset doesn't help!
    05-19-2018 05:36 PM
  11. ronaldhefner's Avatar
    This happens constantly on my LG G5. The volume is unstable on the ringer, notification sounds, videos, Google Maps driving directions, and apps. I have a sleep sound app that starts out at full volume, then it goes down, then it comes back loud. I tried installing Persist, a volume control app. Didn't help. It's driving me crazy, and I suspect that it's common on these models--a software glitch that's built right in. Sorry I ever bought this phone.
    07-08-2018 08:56 AM
  12. nukaronie's Avatar
    Hey I know this thread is kinda old but I'm having the same issue of my LG phone (LG Stylo2) randomly getting the media volume lowered (the slider does not move though) and I'm starting to get a bit annoyed especially when I'm trying to listen to music. This has been happening for the past 2 days and I tried restarting my phone and it did work for a couple hours then the issue came back. I was wondering if there is an actual fix for this?
    08-12-2018 10:20 PM
  13. jhngoodrich's Avatar
    I have a 2 year old Samsung 10.1 Tab A, Model SM-T580 and I've been having this exact problem. Have you found a solution?
    pissedLGuser likes this.
    08-13-2018 09:42 AM
  14. ctsr1's Avatar
    I have a LG v30 and am having the same issue across all media game YouTube streaming. It doesn't matter. No fix yet
    09-04-2018 11:23 AM
  15. pissedLGuser's Avatar
    I've been having same problem with a 6 month old lg k20. Total crap. Have tried factory reset. Uninstalling apps. Clearing cache. Safe mode, blah blah blah. At the MetroPCS store they look at me like I'm stupid when I describe the problem and try to sell me another phone. I've never had good luck with LG anything. Now people are saying even Samsungs are doing it. I can't bring myself to switch to The Devil's phone (iPhone). Please someone help!
    09-17-2018 07:13 PM
  16. Skylsmoi's Avatar
    Hi, just found this thread and I think I'm having the same issue.
    From my tests, the media volume get lowered down by the system after being at max lever for while.
    It usually happens while I'm driving with spotify at max level on my phone (to have better volume control from my car inputs)
    It looks like an ear protection system but I can't find a way to disable it.
    It was already happening on my previous phone and still happening on my new one.
    04-15-2019 11:23 AM
  1. Replies: 4
    Last Post: 03-26-2015, 03:36 PM
