1. mikeyg00's Avatar
    I solved my lollipop battery overheating issue with a factory reset.
    Now I'm trying to add back the digital clock widget to the home screen. With the Google now launcher, it's no longer an option.
    Options? I really need a larger clock and date on the home screen, that's it.
    05-05-2015 03:08 PM
  2. durango992007's Avatar
    Take a look at minimal clock. I use it and it's great. Says time, date and battery life if you want. You can change the appearance also
    05-05-2015 03:47 PM
  3. mikeyg00's Avatar
    Where do you get this?
    05-05-2015 04:18 PM
  4. mikeyg00's Avatar
    Haha, I didn't realize I could get widgets from the app store.... All along I've just been using the ones on my phone....
    05-05-2015 04:31 PM
  5. Grovzy1080's Avatar
    Try Zooper Pro. You can make you own widgets.
    05-05-2015 06:22 PM
  6. draskome's Avatar
    Chronus clock widget is one of the best and most simple to configure clock widgets..
    It is developed by the developer that created official Cyanogenmod clock widget.
    05-06-2015 06:56 AM
  7. xocomaox's Avatar
    Yes, welcome to a new age of technology where you can get replacements for whichever apps you don't like currently on the phone.
    Chronus is the best I've ever used. Go for Pro, it's worth it.
    05-07-2015 11:12 AM
  1. Will the Note 5 have removable battery and storage?
    By Kevin OQuinn in forum Samsung Galaxy Note 5
    Last Post: 08-13-2015, 10:10 AM
  2. Why is my battery draining so terribly on my Nexus 5?
    By Gary_Berg in forum Google Nexus 5
    Last Post: 05-08-2015, 08:30 PM
  3. Why is my battery dead after less than a month of use?
    By Daniel Miner in forum General Help and How To
    Last Post: 05-06-2015, 04:09 AM
  4. front camara issue
    By naresh bathula in forum Samsung Galaxy S5
    Last Post: 05-05-2015, 05:06 PM
  5. Replies: 0
    Last Post: 05-05-2015, 01:09 PM
