Hey Google, open the garage door! $50 Garage Door Opener
05-18-2015 02:57 PM
26 12
tools
  1. bhameyedoc's Avatar
    Best4Power 4500mAh extended battery impressions-0506151048-01.jpgBest4Power 4500mAh extended battery impressions-0506151048a-01.jpgBest4Power 4500mAh extended battery impressions-screenshot_2015-05-06-17-33-04.jpgBest4Power 4500mAh extended battery impressions-screenshot_2015-05-06-17-33-10.jpg
    4500mAh Extended Slim Battery for LG G3 VS985 D850 LS990 D851 US990 D855 Phone | eBay
    I decided to give this extended battery a shot. I was skeptical of course, but I wanted to give you my initial impressions. Keep in mind that this is my first week with the battery. The battery itself states 5000mAh, but the ebay description shows 4500. It is the same size as the oem battery, but a little heavier.
    I ran it through the suggested power cycles by leaving on Netflix with the screen at 100% brightness. I am amazed that I got over 4 hours of screen on time with 100% brightness and 2% battery left for the past two power cycles! I am usually lucky to get anywhere near 3 hours of screen time at 40% brightness with the oem battery. Also, at no time when I checked the phone did it feel overly warm. With the oem battery, I have gotten warnings about the phone being too hot.
    The battery is $19.85 with free shipping, and after another week of trying it out on a regular basis, I will probably order another for a back up. I'll give more feedback on this forum after I use it more. Just wanted to pass this along for people looking for extended batteries.
    PS - I am rooted with stock and using Amplify and Greenify.
    donm527#IM, belodion and xocomaox like this.
    05-07-2015 11:50 AM
  2. donm527#IM's Avatar
    Ordered. Keep us updated on how it run.
    I've been looking for a extended battery OEM sized.
    For $20 worth giving it a try, Thanks.
    05-07-2015 02:34 PM
  3. donm527#IM's Avatar
    BTW, can anyone recommend a battery app that can get readings and give detail on battery installed? When I get mine would like to see if app will tell truely the mah as well as other battery info if possible and compare it to OEM.
    05-07-2015 02:37 PM
  4. atlas9171's Avatar
    CPU-Z should do the trick. I would think.
    05-07-2015 02:59 PM
  5. xocomaox's Avatar
    CPUz does not tell you the actual MAh of the battery. You would need a battery reader for this.
    Could you show us Screen on Time under normal usage?
    05-07-2015 03:38 PM
  6. donm527#IM's Avatar
    Checking google play, it says Version 1.09 update they added Battery capacity (in mAh).
    05-08-2015 07:21 AM
  7. systemind's Avatar
    So this is a bigger battery that fits in the standard space without making the phone bulkier?
    05-08-2015 08:41 AM
  8. xocomaox's Avatar
    All that does is read what you phone is supposed to have so it will say 3000 regardless of how large your battery is. This is not an actual reading.
    From what I understand, yes. I want to purchase one but still would like to see normal usage screen-on-time. Nobody runs at 100% all the time unless they are in direct sunlight.
    05-08-2015 09:29 AM
  9. bhameyedoc's Avatar
    Give me a couple of days to see how it does under normal usage, and I'll let you know. Also, just to see how it compared, I ran the oem battery at 100% brightness on Netflex and got about 45 minutes less of screen time than the replacement battery. I did notice the phone ran hotter with the oem battery.
    vicks88 likes this.
    05-08-2015 09:53 AM
  10. koves's Avatar
    Whoa I think I'm gonna order this
    Posted on my LG G3 via the Android Central App
    05-08-2015 11:27 AM
  11. xocomaox's Avatar
    Thanks, that would be helpful.
    I've found with my 3rd party 6,000MAh battery it runs a lot cooler as well.
    05-08-2015 11:43 AM
  12. vicks88's Avatar
    How it performs with auto-brightness?? Whats the SOT??
    05-09-2015 12:13 AM
  13. cliffords's Avatar
    I purchased a battery similar/same as described (4xxxx) some 7 months ago. I believe in carrying a spare. I haven't noticed a difference between the original or my newer one. Aside from label's I cannot see a difference.
    That said, the G3, as far a my personal experience is concerned, gets great battery life.
    In this competitive world battery life is measured and compared. I am sure if a knock-off battery, the same size, got much longer up-time, LG would use it.
    That doesn't make the knock-off bad, just don't expect miracles.
    CliffordS
    05-09-2015 11:18 AM
  14. systemind's Avatar
    Any new updates on how the battery is working?
    05-09-2015 08:10 PM
  15. dnafog's Avatar
    My Hyperion 6000mAh with TPU case is rocking for me since the L update.
    I would be interested in a stock size hi-cap battery though, FWIW.
    05-10-2015 01:15 AM
  16. bhameyedoc's Avatar
    So far, I would say that I get about 1-1.5 more hours out of the Best4Power battery than oem, but nothing remarkable. Keep in mind I've only been using it on a regular basis for about 3 days now. I usually leave my phone on the charger at work, so I am trying to remind myself to not charge it during the day to see how the battery does.
    I don't regret buying it, because it certainly isn't any worse than the oem battery. It gets me from 6 am to 10-11 pm with moderate use and a little juice to spare. I usually keep the screen at 40%. I know some people post about how great their battery life is with the G3, but mine has been average. Battery life has been the only let down for me since moving away from the Droid MAXX, but honestly, I don't think there is another phone out there that could match that type of battery life right now. I do like being able to carry a spare battery around, though. :-)
    05-11-2015 04:02 PM
  17. donm527's Avatar
    Just got mine in the mail. Gonna follow the instructions on ebay and drain and charge and see how it performs tomorrow under regular use.
    $20 for a replacement battery that's cheaper than getting an extra OEM and get 1-1.5 hour more screen??
    I don't see myself needing or wanting to swap batteries but now I'll have my original OEM as a spare if needed.
    05-11-2015 06:43 PM
  18. bhameyedoc's Avatar
    I've also used the Anker 3000 mAh battery, which I feel gives comparable performance to the oem battery. You can also buy a two-pack with a charger. The charge is pretty slow, but it can come in handy if you need it.
    http://www.amazon.com/gp/product/B00...cUvbUpU4420636
    http://www.amazon.com/Batteries-T-Mo...cUvbUpU4420636
    05-11-2015 07:15 PM
  19. bhameyedoc's Avatar
    How thick is the phone with this battery? I would want something that still fits easily into my pants pocket.
    05-11-2015 07:31 PM
  20. gtcharlie's Avatar
    I have had this battery for about a month and a half. It adds no bulk to the phone. However I haven't really noticed much improvement in battery life than the stock battery. I certainly have not experienced one and a half battery life like the math would tell you I should be receiving. Having said that it is not bad for the price if you want a back up battery.
    05-12-2015 08:58 AM
  21. xocomaox's Avatar
    I'm going to chalk this battery up to an advertised larger capacity that is no better than the oem battery until I see a more comprehensive review like what I've posted here: http://forums.androidcentral.com/lg-...ery-lg-g3.html
    05-12-2015 09:25 AM
  22. donm527#IM's Avatar
    I'll have to go through the conditioning, cycling the battery a few times to see if there is really any improvement...
    but when putting in the new battery the website says to use up whatever charge in the battery at initial install and then do a full charge, I still had 60% left and with brightness bumped up to 95% from my normal 70%, it took me about 2 hours of you tube, 30 minutes of recorded video from my gallery, about 10 minutes of streaming video from my cnbc app and 30 minutes of navaigation to work to drain it.
    With the OEM battery on a regular day use I don't get much more than 3 hours screen time before battery gets low. So to get 3 hours from 60% I find impressive for me. Fully charged in less than 2 hours and using it now it's drained 10% in 90 minutes pretty fast and will see how battery does after I've drained the battery a few times and should be conditioned.
    05-12-2015 09:55 AM
  23. gtcharlie's Avatar
    Definitely sounds like you are getting better battery life than me. Could be differences in the batteries themselves I guess. I did all the conditioning recommended and didn't notice much change. To be fair I do believe this battery to have slightly better battery life than the stock one. Just not the jump I was expecting.
    05-12-2015 11:25 AM
  24. donm527#IM's Avatar
    Still going through the process of conditioning the Best4Power battery I got from Ebay, draining it 3-5 times but this is my 2nd or 3rd full charge.
    I always keep it at 70% brightness. I feel it's a solid battery for the price... doesn't drain fast when not in use which is just as important than on screen for me. And in mix use, off and on, I am happy getting at least 3 hours screen time with the total available time like the 42 hours of total time shown below.
    If I just wanted to test screen time going 100% to 0 immediately, I could stream youtube or CNBC live from full charge and get another hour of screen time easy.
    Best4Power 4500mAh extended battery impressions-screenshot_1.jpgBest4Power 4500mAh extended battery impressions-screenshot_2.jpg
    05-18-2015 10:25 AM
  25. xocomaox's Avatar
ID:	177036Click image for larger version.
    So it's no better than stock battery from LG? That's what I am getting from your post.
    Meanwhile with my 6,000mah battery...
    Attached Thumbnails Best4Power 4500mAh extended battery impressions-battery.png
    05-18-2015 02:42 PM
26 12
  1. Battery drain overnight
    By Erm10 in forum Samsung Galaxy S6
    Last Post: 02-17-2018, 08:03 AM
  2. Replies: 38
    Last Post: 06-01-2015, 02:10 AM
  3. i have a lg g2 d800 is strucked and poor battery life
    Last Post: 05-26-2015, 06:34 AM
  4. How do I fix battery drain issue?
    By aweyrich in forum Android 5.0 Lollipop
    Last Post: 05-26-2015, 06:33 AM
  5. Replies: 0
    Last Post: 05-07-2015, 12:33 AM
