1. MariahCareys FriendClub's Avatar
    I bought my LG G3 from T-Mobile. Since my purchase I traded in the phone at least 4+ times in the last 7 months because it keeps randomly rebooting until it loops. Ex. turns on then off, then on again and off again over and over. In the last 30 days I exchanged the phone twice. Every phone I exchange has the same problem. Like the reboots just transfers from one phone to the next one like a virus. I did a factory reset numerous times to the point where I do not install any apps or upload any google accounts. It still does it. What is this virus that follows me from one phone to the next. Tmobile will only exchange for same make and model under warranty. Please help me fix this phone glitch. It is very frustrating and am out of a phone because of this.
    07-19-2015 12:54 PM
  2. srkmagnus's Avatar
    Do you notice the rebooting after downloading or using a particular app or service? I think that's what is causing the problem... Try a reset and see if the problem continues after using a particular app. Let us know if you have any other questions.
    07-21-2015 05:50 PM
  3. pinball_wiz's Avatar
    Same for me.
    I did a factory rest, installed no apps and the only way I can stop it from rebooting over and over again is to plug it in. Then sometimes I can get it to boot. Then I can unplug it (battery shows 90+% full) and use it for a few minutes before it reboots again.
    Thoughts?
    08-15-2015 01:19 PM
  4. underway99's Avatar
    It's possible that your SD card could be the issue. I had a similar issue with two different devices (but the same card). The phone would boot and run until it accessed the memory card, then it would lock up. Sometimes it would restart on its own, and sometimes I had to pull the battery. Regardless, so long as the memory card remained installed, the phone remained in a boot loop. I removed the memory card and the phone worked. It happened about six months later in a new phone because I'd forgotten to destroy or at least label the bad card. Replacing the SD card was the fix.
    Pedalbflat likes this.
    08-15-2015 03:50 PM
  5. Teddy Pramana Putra's Avatar
    Same for me.
    Thoughts?
    Exactly what happened to me. Did you find the solution?
    08-17-2015 10:34 PM
  6. ArabianPrincess786's Avatar
    I don't use a SD card on it anymore yet mine does the same.
    09-07-2015 03:25 PM
  7. Shoulders's Avatar
    Hi guys, I had the same problem. Started happening every so often, then one evening just kept rebooting in a loop. Only thing that stopped it was plugging it in via USB.
    I read one thread where someone suggested a new battery would solve it. It made sense as the only way to stop the reboot was if it was being powered by USB. Ordered a new one and problem solved. In my case it was a simple as swapping out the battery.
    Hope this helps.
    belodion likes this.
    09-08-2015 04:13 PM
  8. Lally Ocampo's Avatar
    But my battery seems totally fine.
    09-14-2015 10:57 PM
  9. Jim Mardis's Avatar
    I've purchased brand new OEM LG batteries. They both did the same thing.
    Reboots forever. I thought the vendor might have a bad batch so I ordered a
    third from another vendor. Same issue. Three strikes and its out.
    08-15-2016 08:44 PM
  1. LG Health/Fitness App -- Working for Anyone?
    By Peter Venkman in forum LG G4
    Last Post: 07-08-2016, 03:45 AM
  2. Upgrading to Nexus 6 will my old sim card work?
    By tonyr6 in forum Google Nexus 6
    Last Post: 07-24-2015, 11:00 PM
  3. Replies: 2
    Last Post: 07-19-2015, 01:10 PM
  4. Replies: 1
    Last Post: 07-19-2015, 12:15 PM
  5. Why does my LG G3 Keep rebooting over and over?
    Last Post: 07-19-2015, 12:14 PM
