1. AC Question's Avatar
    My lg g3 suddenly won't connect to home wifi. It will connect to other wifi and other people can connect to mine. My friend has the same phone and his won't connect to my wifi either. So far I've tried replacing the router , forget and add network, and factory reset. Nothing works.
    07-28-2015 03:43 PM
  2. Rukbat's Avatar
    Try setting the router to use AES, not TKIP or TKIP+AES. (Some of the better routers, like Linksys, won't even work that way. I ended up buying a cheap Netgear WNR2000 [$40] and everything works if it's set to AES.)
    07-28-2015 05:17 PM
  1. Why isn't my moonshine calendar changing the date?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 07-30-2015, 06:43 AM
  2. Is my oneplus one doomed?
    By JO3KUL in forum OnePlus One
    Last Post: 07-28-2015, 04:24 PM
  3. Replies: 1
    Last Post: 07-28-2015, 03:37 PM
  4. Replies: 0
    Last Post: 07-28-2015, 03:22 PM
  5. Why can't I take a screenshot on my LG 7.0 pad?
    By AC Question in forum LG G Pad 7.0
    Last Post: 07-28-2015, 03:04 PM
