1. Jezza819's Avatar
    A few days ago I had updates for both Light Flow and Verizon Messages+. Light Flow still works for the other functions I have it set up for, red flashing light for charging the battery and green light for fully charged. But it's stopped working for Messages+ when I get text messages. Something must have changed in Messages+ where you allow Light Flow to handle notifications. I've went into Light Flow and double checked that everything is set correctly and if I test the notification for text messages the light will flash. It just won't flash when I actually receive a message.
    Anyone else seen this issue?
    08-13-2015 08:31 AM
  2. Jezza819's Avatar
    Just as a followup to this issue. I contacted Light Flow and to my surprise someone contacted me back, I'm guessing one of their engineers, and said he was working on an update to fix this issue and they were aware of it. This was last last week so hopefully that update will be out soon.
    09-08-2015 10:36 AM
  3. riverlee's Avatar
    thanks for the info, any update on this? I just sent them an email also so I will see if they respond.
    10-14-2015 11:54 AM
  1. Verizon updates the note 4 for stagefright security fix
    By pstellato73 in forum Samsung Galaxy Note 4
    Last Post: 08-14-2015, 12:26 AM
  2. I cannot stop notifications
    Last Post: 08-13-2015, 09:23 AM
  3. I cannot stop notifications
    Last Post: 08-13-2015, 08:47 AM
  4. Why did I see this message?
    By onnad in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 08-13-2015, 06:40 AM
  5. Factory reset/hard reset doesn't work
    Last Post: 08-13-2015, 06:27 AM
