To toggle Roaming, go to Settings (gear icon), Mobile Data, Overflow Menu (3 dots), then Mobile Networks. Uncheck Data Roaming.
Not sure if all G3 variants get there the same way but hopefully similar.
As for calls, you "sort of" always roam but will not get charged unless you make or answer a call, retrieve voicemail or send text messages. By "sort of", I mean that the G3 will use other networks when the home network is unavailable for emergency calls (e.g. 9-1-1) only. I believe that most modern smartphones now do this.
08-21-2015 01:11 PM
