1. coachpelkey's Avatar
    I have a feeling this is a battery situation : but I thought I would ask.
    If it is, can anyone suggest some...but I digress. Please help
    I have been using my spring lg g3 for the last 10 months with no real problems. Yesterday after downloading a sprint update for something that I didnt even ask for...or approve, I turned my phone off to go to work. When I got off work, I turned it on and it was stuck in bootload LG life is good 1st screen.
    It would flash the screen and go off, flash the screen and go off. I tried to factory reset from the recovery screen, pull the battery all that fun stuff.
    I plugged it into my computer, and within 3 min, it factory restarted. This lasted until the battery got around 50% and then went right into the soft brick mode. Very frustrating.
    Its currently stock, non root...never rooted
    running android 5.01, kernal 3.4 , build ls59902va
    I am going to cross post this and see if anyone can help.
    Thank You
    08-30-2015 10:00 AM
  2. Golfdriver97's Avatar
    I am not that proficient with LG devices. The ROM might have to be reflashed. I would take it into a Sprint store and see if they can reflash it.
    08-30-2015 10:17 AM
  3. coachpelkey's Avatar
    Thanks. Sorry about cross posting
    They are not open until tomorrow.
    Even with a non rooted phone I would need to reflash...?
    I have the tools and info to use the lg flashtool just trying to hold off.
    08-30-2015 10:19 AM
  4. coachpelkey's Avatar
    Just an update-
    Looks like the battery.
    Cannot prime it at the Sprint store...
    Oye. Any suggestions.?
    08-30-2015 12:38 PM
  5. Golfdriver97's Avatar
    First...no worries about cross posting. Second, even with a non rooted phone, it could still need a reflash. If you'd like to try yourself, go for it. However, if it were me, I would take it in.
    Sent from my Nexus 5 using Tapatalk
    08-30-2015 02:58 PM
  1. Why isn't my Play Store working?
    By AC Question in forum Google Play Store
    Last Post: 09-08-2015, 04:11 PM
  2. Replies: 1
    Last Post: 08-30-2015, 10:22 AM
  3. Spring LG G3 Boot Loop/Soft brick under 60%
    By coachpelkey in forum General Carrier Discussion
    Last Post: 08-30-2015, 10:19 AM
  4. Why isn't my private mod working after rooting?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 08-30-2015, 09:01 AM
  5. Can I get some help rooting my SPG512 Xperia Z2 tablet?
    By Slashyou in forum Sony Xperia Z2 Tablet
    Last Post: 08-30-2015, 08:56 AM
