1. bigmick777's Avatar
    My g3 (d855) Came with a uk plug 1.2 mah charger and usb cable.
    Out of all my chargers it has been by far the best. Suspect the lg cable which was labelled as 20awg helps.
    Anyway, I have lost this faithful charger and want a genuine or solid performing replacement. EBay genuine items worry me and a lot of the "genuine" chargers listed are 1.8mah. So thought I would get any feedback you guys may have....
    09-05-2015 02:16 PM
  2. gehirnmacht's Avatar
    Mine is D855 and came with 1.8 Amp charger ... And you may also get one of the smart chargers that adjust the amperage as your phone needs ... I use one called Anker 5 port 48 wt charger with power IQ technology and it is good so far ... Hope this helps ...
    Sent from my LG-D855 using Tapatalk
    09-05-2015 03:12 PM
  1. Replies: 5
    Last Post: 10-15-2015, 09:43 PM
  2. My GN2 dies after I unplug it from Charger
    By AndroidIsLife10 in forum Sprint Galaxy Note 2
    Last Post: 09-04-2015, 11:18 PM
  3. My GN2 dies after I unplug it from my charger.
    By AndroidIsLife10 in forum Samsung Galaxy Note 2
    Last Post: 09-04-2015, 11:14 PM
  4. Replies: 0
    Last Post: 09-04-2015, 02:50 PM
  5. Replies: 0
    Last Post: 09-04-2015, 02:38 PM
