1. AC Question's Avatar
    Sounds stop when I plug in my LG G3. It doesn't happen immediately, but within 10 seconds, all sounds stop while its charging. Any ideas or suggestions to fix?
    12-28-2015 10:21 AM
  2. Shane English's Avatar
    Does your phone make a notification sound when plugged in?
    12-28-2015 10:22 AM
  3. pockystick's Avatar
    12-28-2015 10:30 AM
  4. Shane English's Avatar
    I had this before on a phone search through your sound settings to turn this off. Then restart the phone and see if this fixed it
    12-28-2015 10:32 AM
  5. pockystick's Avatar
    huh? "search through your sound settings to turn this off" turn what off?
    12-28-2015 10:39 AM
  6. Shane English's Avatar
    On most phones there's a setting to turn charging sounds off
    12-28-2015 10:41 AM
  7. pockystick's Avatar
    Its not the charging sound I'm worried about. Its the fact as soon as I plug it in, I don't hear any sound when playing a video.
    12-28-2015 10:43 AM
  8. Shane English's Avatar
    Yes this is what I'm getting at it the charging sound that is bugging out your phone
    12-28-2015 10:44 AM
  9. pockystick's Avatar
    I went to SETTINGS, VOLUME, and turn TOUCH FEEDBACK& SYSTEM and Notifications all the way down. Restarted the phone and started playing a video, plugged it in and with 20 seconds, the sound stopped again.
    12-28-2015 10:54 AM
  10. NorlanBustilloX's Avatar
    I have the exact same problem, and was about to make a new thread about it, but decided to check a few pages to see if this was mentioned somewhere else. What pockystick means is that when the phone is charging and starts any audio playback (music, videos), the sounds cut off. What I do to get the sound back, but just for a couple of seconds until it shows again, is to pause the audio for 2 seconds and press play again. It solves the problem, but again, just for 10 seconds at most. Any ideas?
    01-04-2016 02:20 AM
  11. lyd76's Avatar
    I had this same exact problem... after looking everywhere I couldn't find a solution so I just gave up. Just recently I noticed I don't have this problem anymore. I don't know what I did. My charger has been acting up so I used a toothpick to clean out the port, I don't know if that was the problem. Who knows? :'(
    01-05-2016 07:43 AM
  12. NorlanBustilloX's Avatar
    So, no one knows anything?
    01-12-2016 03:17 PM
  13. profkefah's Avatar
    i am owner of mobile phone shop
    some of customer had same issues
    solution was
    by changing charger or charging cable
    12-19-2016 11:28 AM
  1. why do apps keep downloading to my phone
    Last Post: 12-28-2015, 01:47 PM
  2. how can i fix my keyboard from disappearing on my lgms769
    Last Post: 12-28-2015, 10:21 AM
  3. Replies: 1
    Last Post: 12-28-2015, 10:20 AM
  4. Replies: 1
    Last Post: 12-28-2015, 10:18 AM
  5. Replies: 0
    Last Post: 12-28-2015, 09:52 AM
