1. AC Question's Avatar
    The only way I can get the charge to increase is to turn the phone off. Then the phone will fully charge.
    03-10-2017 11:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is the phone plugged into a wall outlet or a computer USB port? Are you actively using the phone when you notice this, or is it sitting idle?
    03-11-2017 10:35 PM
  1. How do I get my pictures off of my phone and onto my SD card
    Last Post: 03-11-2017, 10:43 PM
  2. Can I temporarily disable the system update?
    Last Post: 03-11-2017, 10:39 PM
  3. What have to do for the app no opened
    Last Post: 03-11-2017, 10:37 PM
  4. Is it okay to charge an S5 battery with an S4 phone?
    Last Post: 03-10-2017, 11:44 PM
  5. Replies: 1
    Last Post: 03-10-2017, 11:34 PM
