1. AC Question's Avatar
    the method to fix your lgg3 wifi and miracast problems is extremely simple turn off your device take off the back cover & remove the battery and sim card and any memory cards then press the power button for around 15 seconds this drains any excess power that helps cause a conflict with various signals, insert your sim card memory card and & battery put the cover back on and switch your phone back on and you will find the overall performance of your device will improve I have had my lgg3 for over 3 years now
    belodion likes this.
    08-10-2017 04:03 PM
  2. Gerry McBurney's Avatar
    I will give that a try. Thanks.
    08-11-2017 03:00 PM
  3. ryandigweed's Avatar
    Did it work ?
    12-21-2017 01:02 AM
  4. iMagom's Avatar
    Great solution. Thank you very much. I fixed problems with WiFi and Hotspot.
    12-31-2017 05:34 AM
  1. Replies: 17
    Last Post: 08-16-2017, 10:56 PM
  2. how to send text thread to someone
    By sadomasochryst in forum Samsung Galaxy S8 & S8+
    Last Post: 08-11-2017, 04:38 PM
  3. Is it possible to input video to a Galaxy 8 via the USB port
    Last Post: 08-11-2017, 05:50 AM
  4. Replies: 0
    Last Post: 08-10-2017, 03:27 PM
  5. Replies: 0
    Last Post: 08-10-2017, 03:01 PM
