1. Nikos27's Avatar
    Hello guys, I have a LG G3 with android 5.0 installed, bought it new one year ago. No issues until a week ago where I opened the gallery and realised that I did have many black photos taken, like while having it in the pocket, then opened Camera and reveived a message “Unfortunately camera has stopped”. Rebooted but again the same message. After a few hours the back camera did work but I noticed that the camera switch Icon was missing. No drops or something. Just happened.
    Have already tried to:
    -Factory reset
    -Hard reset from manufacture menu
    -Restore from Backup
    -Delete cache/data from Camera and/or Gallery
    -Download other camera apps
    -Use Messenger Skype Viber etc.
    Nothing works. Its like the system doesnt recognise the that theres another camera there.
    There is not the option to return the phone cause I live in different country now.
    I would prefer not to root mostly because I am not familiar with the procedure and I cannot afford to buy new phone in case something goes really wrong.
    Please if someone would suggest any ideas, I would be grateful. Thank you!
    02-22-2018 09:05 PM
  2. Rukbat's Avatar
    The camera module - a piece of hardware mounted on the motherboard - has stopped working, just as it says. That means that you need a new camera module. Depending on how much the repair shop will charge to replace it, it may be as cheap, or cheaper, to replace the phone.
    02-23-2018 03:46 PM
  1. How can i fix colored e-ray effect on my lg k8 phone
    Last Post: 06-10-2018, 11:01 AM
  2. Replaced motherboard, now touchscreen doesn't work
    By Sarawithanh in forum Legacy Android & Other OS's
    Last Post: 02-23-2018, 09:46 PM
  3. My audio jack for my LG G6 isn't giving me full quality!
    Last Post: 02-23-2018, 03:52 PM
  4. is the android one moto x4 phone considered an unlocked phone?
    Last Post: 02-22-2018, 07:57 PM
  5. Why is my led lights not working on my galaxy j3
    Last Post: 02-22-2018, 06:56 PM
