1. Dezso3's Avatar
    Which battery should I get for my LG G3? I got an original BY-53YH brand new one off of Amazon that was manufactured in 2017, but for some reason, it became worn out very quickly. After just a year or so of use, it started to die very rapidly. So which one should I get instead?
    12-16-2018 12:56 PM
  2. Rukbat's Avatar
    Did you let it drop below 40%? That would explain it. Or the battery was made in 2017 - from cells that were made in 2014. (That's one reason phones get replaced when they still work well enough for the owners - you can't get decent batteries for them after 4 or 5 years - they're all shot.)
    Try charging it to 100%, then using it until it does completely. Do that cycle a total of 3 times. If that doesn't bring it back, consider it shot. (Then you can try your carrier, or LG, but you probably won't find any in better condition.)
    12-16-2018 03:50 PM
  1. Replies: 2
    Last Post: 12-16-2018, 09:11 PM
  2. my infinix hot s is asking for privacy protection password to unlock
    Last Post: 12-16-2018, 02:48 PM
  3. Replies: 1
    Last Post: 12-16-2018, 01:00 PM
  4. How can i choose the best memory card for my infinix hot6 pro
    Last Post: 12-16-2018, 11:52 AM
