    I am having a real problem with my LG G3 at the moment, right now i am unable to enter the download mode and it has a bootloop problem. I can try and enter recovery mode but since there is no recovery mode like twrp for instance, i cant do much there either.
    Now the bootloop problem is basically the lg logo showing for about 10 minutes, when you finally see android is starting and setting up apps, it will just turn of and on again, i checked and the battery is fine and so is the power button so its not a hardware problem.
    As for what happened, a friend of mine was going to flash a kernel onto it, but flashed the wrong one for i believe a different model, which is the reason these problems started happening.
    I have tried fastboot, download mode and recovery mode, but all do not seem to be working.
    Does anyone have any ideas as to what could fix this? Please let me know.
    And i know people might want to know the model but thats kinda hard to figure out when it wont properly boot.
    06-30-2019 07:16 PM
  2. mustang7757's Avatar
    Hi , if you can make a account here ,me or another might be able to help.
    If you can't get into download mode to flash the stock firmware, you can get in recovery might have a chance at ADB command to install the firmware that way , but definitely prefer download mode if u can get in it.
    06-30-2019 07:53 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Welcome to the wonderful world of LG bootloop problems. The G3 and G4 were notorious for this. See this thread, among others: https://forums.androidcentral.com/lg...onstantly.html
    06-30-2019 09:46 PM
  4. mustang7757's Avatar
    Forgot about the lg bootloop .. motherboard problems.
    06-30-2019 09:58 PM
  1. Text message notifications not appearing in notification bar after restart
    Last Post: 07-02-2019, 08:01 PM
  2. What is com.lge.launcher3 and what is it used for
    Last Post: 06-30-2019, 09:50 PM
  3. Visual indication on phone as to whether Wifi or data being used for music?
    Last Post: 06-30-2019, 07:26 PM
  4. Cant send photos in my Facebook massge.
    By Android Central Question in forum Android Apps
    Last Post: 06-30-2019, 05:35 PM
  5. Cant send photos in my Facebook massge.
