    Recently on my LG G4 the battery cover keeps coming off. The top and bottom snap but it don't hold very good. If I squeeze to tight it'll come off.
    I ordered a cover from ebay. Leather one. Shouldn't that fix the problem?
    I think the reason being I had to keep pulling the battery out and put it back in. Maybe the clips on the cover broken off I don't know.
    It was a bad battery which I did replace.
    05-03-2020 03:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I moved this to the G4 forum for more specific traffic.
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    05-03-2020 03:23 PM
  3. Morph247's Avatar
    Okay cool thanks. I just registered.
    05-03-2020 04:21 PM
  4. Morph247's Avatar
    Anyways this is what I bought. Hopefully this will fix it. As it is right now it hardly stays on.
    https://rover.ebay.com/rover/1/711-5...f-75aac1e423c0
    05-03-2020 04:30 PM
  5. Morph247's Avatar
    Update. Well for the order in just now. Took old cover on and put this one on. Worked like a charm and it feels and looks sturdier then the original gloss one I had.
    B. Diddy likes this.
    05-04-2020 03:36 PM
  1. My keyboard now pops up and covers everything and is pink
    Last Post: 05-03-2020, 09:20 AM
  2. my LG Stylo 5 has a peculiar tic
    By Rezmodroid in forum Ask a Question
    Last Post: 05-01-2020, 05:43 PM
  3. How do I decrypt storage on my lg stylo 4 phone if I never set a password?
    Last Post: 05-01-2020, 03:41 AM
  4. How do I change the number of rings before my LG Rebel 4 LTE goes to voicemail?
    Last Post: 04-30-2020, 07:23 PM
  5. Why dose mip 67 pop up all the time on my lg stylo 4
    Last Post: 04-30-2020, 04:19 PM
