1. johnts's Avatar
    Wondering if any of you have tried to run the 'smart cleaning' app under the general settings. My phone will calculate how much to clean, but when I try to run it I get the usual app fail message of smart cleaning has stopped.
    I tried a battery pull, cleaned system cache, all of the tricks. Nothing has helped to resolve it.
    I sent an email to LG support about it and a couple other issues, but have not heard back yet.
    Can a few of you try it and see if this LG app works on your phone.
    06-12-2015 02:39 PM
  2. anon(782252)'s Avatar
    Sprint version worked fine. It calculated and then I was able to delete app cache under temporary with no problem.
    06-12-2015 02:46 PM
  3. Zendroid1's Avatar
    T-Mobile version works fine.
    06-12-2015 02:51 PM
  4. belodion's Avatar
    Working here, unlocked International, UK.
    06-12-2015 03:10 PM
  5. Jonneh's Avatar
    Worked on my AT&T version as well.
    Strange. Have you tried rebooting and running it again?
    06-12-2015 03:32 PM
  6. johnts's Avatar
    Yes I have including a battery pull. No difference.
    I have a problem with vibrate mode where it will not use anything put the factory setting. If I set it to another pattern that LG provided, it will not be used.
    Since I am having problems with the VZ network signal sometimes also, I think I may ask for a new replacement G4 before my 14 days is up.
    06-12-2015 04:55 PM
  7. Jonneh's Avatar
    I believe that might be best, because I can say that my vibrate settings definitely change and stay put to what I put them to. I played around with it just last night. Let us know!
    06-13-2015 01:31 AM
  8. H3aTeRzz's Avatar
    06-14-2015 07:56 PM
  9. ibcop's Avatar
    It works correctly on the Verizon model I have.
    06-14-2015 08:24 PM
  10. johnts's Avatar
    I took my phone back to VZ yesterday and they gave me a new one, not a refurb. The no network connection problem seems to be gone and the smart cleaning works. However I still cannot get the vibration pattern to use anything other than the out of the box setting, even though I have it set to something different. I even created a custom pattern and set it, but still is using the factory setting. I setup most of the new phone manually including the apps, but something must have come over from my backup and once again corrupted the vibration coding. I have cleared the partition cache, used smart cleaner, and did a hard reboot. None of these solved the problem. Can anybody point me to where the vibration patterns are stored so I can look there and see if I see a file or something that shouldn't be there. It's like something is turned on to ignore user settings for vibrations.
    06-16-2015 11:31 AM
  1. Smart Lock?
    By Silabus in forum General Help and How To
    Last Post: 11-20-2015, 01:58 PM
  2. Nokia ICON to LG G4 with some concerns
    By Ben Fulks in forum LG G4
    Last Post: 06-13-2015, 01:00 AM
  3. Why does one of my contacts not receive my text messages?
    By gjuape in forum Samsung Galaxy S6
    Last Post: 06-12-2015, 02:59 PM
  4. Replies: 0
    Last Post: 06-12-2015, 02:25 PM
  5. Replies: 0
    Last Post: 06-12-2015, 01:08 PM
