06-22-2015 09:57 AM
30 12
tools
  1. GTS21's Avatar
    Heavy words with friends and internet browsing. This can't be right. Verizon model. Auto brightness with slider at 100%
    06-21-2015 02:09 PM
  2. dpham00's Avatar
    Are you using Chrome by any chance?
    Sent from my Verizon LG G4
    06-21-2015 02:14 PM
  3. GTS21's Avatar
    Yes. Why?
    06-21-2015 02:20 PM
  4. Fred Wilson2's Avatar
    post up a screen shot of your battery stats.
    Fred
    06-21-2015 02:32 PM
  5. dpham00's Avatar
    There was a thread with others using Chrome experiencing high battery consumption. You can try another browser.
    For reference, I was getting about 1% every 2 minutes when using Chrome,but I also use auto brightness with slider around 40%,so that could have some impact too.
    06-21-2015 02:58 PM
  6. Jonneh's Avatar
    My screen can get crazy bright with the auto brightness slider at 70%. I don't understand using the full 100%; unless, I guess, you're in direct sunlight. But that'd just be a temporary increase and then I'd put it right back to my 70% most likely. I'm thinking of seeing how 60% or 50% does for me.
    Your battery definitely shouldn't have dropped that much, but you were potentially maxed out on screen brightness, heavily playing a game (which I believe uses an internet connection to connect you to other players? I don't play it), and also browsing the web a bit...It should definitely take a small hit, in my opinion.
    06-21-2015 03:19 PM
  7. GTS21's Avatar
    Sounds like you weren't doing a whole lot better than me? Recommendations on another browser?
    06-21-2015 03:45 PM
  8. GTS21's Avatar
    Fred
    Not sure how to do that, sorry.
    06-21-2015 03:48 PM
  9. dpham00's Avatar
    Yeah it was pretty close. I tried dolphin but it didn't work well for me. I needed chrome bookmark sync so my choices were limited. In the past, Firefox worked well for me but I haven't used it much on the g4.I just live with the bad battery life.
    06-21-2015 03:56 PM
  10. dpham00's Avatar
    Settings - battery - battery usage.
    06-21-2015 03:57 PM
  11. GTS21's Avatar
    Just for fun yesterday, I put my new G4 and G3 next to each other, put both on full brightness, turned screen to always on, and left them there. Occasionally I changed Web sites in Chrome or opened other programs. In the end, my new G4 beat out the G3 by about 5 percentage points, and both got close to 6 hours of screen on time.
    I see others posting over 4 hours of screen in time, but with constant use on chrome or words with friends, I'd be hard pressed to beat 2 hours screen on time.
    belodion likes this.
    06-21-2015 04:03 PM
  12. KPMcClave's Avatar
    I really have a like/hate relationship with Chrome, and this doesn't help. How ridiculous is it that Chrome can't behave with Android?
    I usually feel like it is a half-...uh...hearted attempt at a browser.
    06-21-2015 04:19 PM
  13. japhule's Avatar
    Words with Friends also downloads a large amount of ads including video ads. They can eat away at the battery also.
    06-21-2015 05:21 PM
  14. anon(782252)'s Avatar
    I use Chrome Dev and have had a good experience with it so far. Haven't seen any battery drain.
    I usually have 25-40 tabs open all the time when I flip thru recent apps.
    I used Access Lock to restrict permissions on it so maybe that is helping.
    06-21-2015 05:35 PM
  15. GTS21's Avatar
    How much screen on time do you get playing on the Internet? What's your brightness setting?
    06-21-2015 05:58 PM
  16. KPMcClave's Avatar
    When I open Access Lock I don't even have the stable version of Chrome listed in the apps there. Am I missing something to allow that?
    06-21-2015 06:10 PM
  17. anon(782252)'s Avatar
    Maybe because it's a system app it isn't there. I disabled out and went to chrome dev immediately since I was using it on my G3.
    KPMcClave likes this.
    06-21-2015 06:33 PM
  18. anon(782252)'s Avatar
    I use Lux for auto brightness. I have no idea SOT just using chrome because it's never all I do on the phone.
    06-21-2015 06:38 PM
  19. GTS21's Avatar
    For those getting incredible battery life, can you please share your settings? I may have to return my phone if I'm getting comparatively horrible battery life. I'd love to hear from more Verizon users.
    06-21-2015 06:39 PM
  20. anon(782252)'s Avatar
    I'm on Sprint and I'll share here if you want more info but I've posted quite a bit in this thread.
    http://forums.androidcentral.com/sho...d.php?t=539295
    My worst day has been about 4 hours SOT and that was with almost 24 hours up time and everything on LTE or 3g.
    If you want more settings, I'll happily post.
    06-21-2015 06:49 PM
  21. jdfry15's Avatar
    I have Verizon. I was getting just over 3 hours of screen time for the first 9 days or so. I did a factory reset and since then I've been getting around 4 to 4.5 hours of screen time. Same usage patterns. I'm not one of those people that says don't sync email, turn off GPS, put screen at 25%. I want to use the features and phone the way it was designed. I would say go into your apps an make sure there aren't notifications aren't on if you don't need them. Like weather or news apps. I keep my brightness at 75% most of the day.
    06-21-2015 07:35 PM
  22. GTS21's Avatar
    I must have a bum phone then, can't think of any other reason. You're getting double my battery life. 75% screen brightness, auto or not auto?
    06-21-2015 07:40 PM
  23. jdfry15's Avatar
    Not auto. I can't use the auto. It's too dim in the day and too bright for me in dark rooms. I would try a factory reset or just exchange it if you can. I'm not getting near the battery life a lot of people report but if I get 4 to 4.5 I'm OK with that. I was on the fence about returning the phone when I was getting 3 to 3.5 hours. That's just not acceptable in my opinion.
    06-21-2015 08:13 PM
  24. GTS21's Avatar
    Any Verizon users getting over 4 hours SOT?
    06-21-2015 08:56 PM
  25. blending juices's Avatar
    absolutely .. habit browser does the trick for me .. chrome, firefox, baidu, cm, opera, dolphin, to name a few, all gluttons for your resources .. then I discovered habit, and have not looked back.
    06-21-2015 09:38 PM
30 12
  1. Replies: 2
    Last Post: 01-05-2018, 06:08 AM
  2. Replies: 7
    Last Post: 09-16-2015, 07:45 AM
  3. How can I get out of recovery mode?
    By Bestroller in forum Google Nexus 7 Tablet (2012)
    Last Post: 06-22-2015, 08:24 AM
  4. Replies: 6
    Last Post: 06-22-2015, 06:29 AM
  5. Replies: 1
    Last Post: 06-21-2015, 12:29 PM
