Not knowing what your situation is, this is an impossible question to answer. Did you have a(n) App that misbehaved? Screen brightness turned up? Bad battery? Bad G3? There are way too many variables to figure out what your G3 problem was, or if there wasn't a problem, you just killed the phone that fast.
So, if there was nothing wrong with your G3 and it wouldn't last a full day, then IMO the G4 will not last a full day either. I got a little bit longer life out the G4, but not much. It's pretty much on par with my G3.
06-23-2015 06:00 AM
