1. TNCattleDog's Avatar
    So I get marginal reception in my house and Verizon gave us a network extender to help prevent missed and dropped calls. When I had my G2, and currently on my wife's G2, the Lock Screen shows "Verizon Network Extender" and the status bar at the top shows the little house symbol with the radio waves.
    My G4 shows neither. Although it does seem to pull in a better 4G signal than the G2 and other phones in our home, it does not connect to the extender at all... even if it drops to 3G.
    Anyone else notice this?
    David
    06-24-2015 01:06 PM
  2. Almeuit's Avatar
    Interesting ... Do you happen to have Advanced Calling turned on for your account?
    06-24-2015 02:40 PM
  3. Stalonage's Avatar
    David
    Just a side question, did they make you pay for it? Because I too have spotty service in my home and last I checked they were going to charge me and arm and a leg for one of those and add to my monthly bill.
    06-24-2015 02:47 PM
  4. Almeuit's Avatar
    I know for some they will charge for the device itself but they shouldn't be adding any monthly charges.
    06-24-2015 02:49 PM
  5. TNCattleDog's Avatar
    Yes, and it is turned on on the G2 as well. G2 connected, G4 not.
    David
    06-24-2015 03:41 PM
  6. TNCattleDog's Avatar
    Nope, it was free and no monthly charges. They sent someone out to measure the signals around my house and determined that the signal was poor enough to warrant a free extender.
    On a side note, when I was first having the signal problems, Verizons answer to me was that I live near a lake and the tower signal was reflecting off the water. Facepalm....
    David
    06-24-2015 03:43 PM
  7. Almeuit's Avatar
    David
    Try turning it off and see if it connects to it.
    tardus and TNCattleDog like this.
    06-24-2015 03:45 PM
  8. TNCattleDog's Avatar
    Well I'll be! Your trick worked!
    Verified by turning advanced calling back on and it disconnected from the extender. Funny thing though, Advanced calling is turned on on my Wife's G2 and it connects to the extender.
    David
    Almeuit likes this.
    06-24-2015 03:58 PM
  9. Almeuit's Avatar
    David
    Yeah that is definitely the odd part -- I am not sure if that is a bug or intended since the Extender is supposed to only work with 3G calls. Glad you found a fix so you can at least get some signal at home. I would bring it to the attention of Verizon though. .
    Tatt2014 and TNCattleDog like this.
    06-24-2015 04:03 PM
  10. dunamis's Avatar
    My phone connects with advance calling on.
    06-25-2015 01:20 AM
  11. Stalonage's Avatar
    David
    The signal was reflecting odd the lake...... Lol. Wow. Thanks for the info though! Hope you're all set
    TNCattleDog likes this.
    06-25-2015 12:15 PM
  12. tardus's Avatar
    David
    Try agitating the entire surface of the lake. That will stop the signal from being reflected. /jk
    But seriously, glad everything is working!
    06-25-2015 12:29 PM
  13. JSAUCE75's Avatar
    Mine connects intermittently. Both with advanced calling on or off. For a while, it would only connect if WiFi was on, but not connected to a wireless network. Compared to my wife's s6, which is always connected to the extender, this thing is a nightmare. I just performed a factory reset. Same results. It could be that I live in a townhome and too many devices are connecting to it. I don't know.
    08-18-2015 10:40 PM
  14. Neera42's Avatar
    Having the same problem with my G4. It only connects to the Extender when Advanced Calling is turned off. *sigh*
    Although I have a good 4G signal the call quality is crap without the extender.
    11-09-2015 05:13 PM
  15. Almighty1's Avatar
    Have a question, what is the make and model of the extenders since I thought all of the extenders were 3G only and not 4G.
    11-10-2015 06:04 PM
  16. Neera42's Avatar
    Mine is definitely an older 3G model. It makes sense that it won't connect to the G4 when Advanced Calling is on, I was just hoping I could avoid toggling it to make a call.
    My G2 connected to the extender just fine even with Advanced Calling on.
    11-11-2015 09:43 AM
  1. Why is my S6 Edge switching from vibrate to sound?
    By comiseth in forum Samsung Galaxy S6 edge
    Last Post: 06-25-2015, 10:36 AM
  2. Verizon's 4G LTE coverage in San Francisco?
    By Aflaaaak in forum General Carrier Discussion
    Last Post: 06-24-2015, 04:35 PM
  3. Replies: 1
    Last Post: 06-24-2015, 01:11 PM
  4. Replies: 0
    Last Post: 06-24-2015, 12:35 PM
  5. How do I mirror a Galaxy S5 to older RCA T.V. MODEL# D52W20?
    By wpbrink in forum Samsung Galaxy S5
    Last Post: 06-24-2015, 12:33 PM
