I've had Google Play Services high battery usage myself, but when trying to fix it, I found that I don't have the option to Uninstall Updates in that app....there is only the Disable option, and when clicked, a message stating that the app cannot be uninstalled.
How does one do that?Turning off Google history tracking worked for me.
Sent from my LG-H811 using Tapatalk
Thank you.There's another thread going on right now about how to possibly fix this issue: http://forums.androidcentral.com/lg-g4/546044-play-services-battery-drain-fix.html
Moderator: Could these 2 threads become 1?
Sent from my VS986 using Tapatalk
I'm not having it take up a high % of battery (less than 4%), but I thought I'd try this out "just for fun". When I went to disable it, I got a message saying "cannot uninstall: this package is an active device administrator" along with a "manage device administration" button -- when I clicked on that button I saw a few apps (Exchange, Key Plus, AirDroid, Screen Off & Lock, and Android Device Manager), with nothing seemingly having anything to do with Google Play services.
This appears to have fixed my play services battery drain. Play services were at or above the level of the screen as far as battery % used for me. So far after this play services aren't even on the chart.
1) Go to Settings / Apps.
2) Swipe down until you find Google Play services. Tap on it. Tap on "Uninstall updates".
I wiped all caches and data for it after uninstalling updates. Not sure if that's necessary.
3) Go to*https://forums.androidcentral.com/e...ails?id=com.google.android.gms&token=Z23ZuYfv and update Google Play services.
4) Reboot
https://forums.oneplus.net/threads/...k-root-privacy-guard-or-script-needed.297708/
What version of Play Services does this reinstall? A newer version or older? What impact does this have on.... Anything?
It will install the most current version. I think it just forces a reinstall of the updates so that whatever was wrong or hanging might be fixed.
That's my impression.
I get the same error another user posted. Can't uninstall due to a system administrator error
Have you tried this, "Actually I forgot but I ran into that too, turn off Android device manager and go back and try again. That's a play service too."?
