1. niknik1971's Avatar
    I have a small problem with my LG.
    The problem is when I plug in my headphones and listen to music the Voice Mate app kicks in.
    I do not know what the problem is (I have done some searching on the net, but could not get an answer that gives me the solution).
    So if anyone knows a way of sorting out the problem (that's if there is a solution to it) I would be gratefully accept it.
    Thanks in advance
    Nik
    07-15-2015 04:30 PM
  2. diamond.lemetre9's Avatar
    Thanks in advance
    Nik
    Ok
    Inviato dal mio SM-G920F utilizzando Tapatalk
    07-15-2015 04:31 PM
  3. Shawn_S's Avatar
    Try clearing the defaults in the voicemate app.
    Settings>app manager>swipe to all>go to voicemate>clear defaults
    07-15-2015 04:50 PM
  4. Jacob_1982's Avatar
    I would check the Smart Settings to see if it is set to automatically open that when head phones are plugged in. It is under the General settings tab, then smart settings.
    07-15-2015 05:44 PM
  5. meskin84's Avatar
    I'm having the same issue with Voice Mate, its really annoying
    07-15-2015 07:15 PM
  6. niknik1971's Avatar
    In the end I did a factory reset, which seems to have sorted out the problem (fingers crossed).
    07-19-2015 06:22 AM
  1. Auto Rotate Problem
    By jimbo1mcm in forum Google Nexus 6
    Last Post: 12-05-2017, 12:47 PM
  2. Problems with keyboard
    By ryanqc in forum Samsung Galaxy S6
    Last Post: 07-16-2015, 02:28 PM
  3. Radio problems on AT&T....any ideas?
    By Winfield_Butlin in forum Samsung Galaxy S6
    Last Post: 07-16-2015, 10:46 AM
  4. Replies: 0
    Last Post: 07-15-2015, 02:42 PM
  5. Replies: 0
    Last Post: 07-15-2015, 02:07 PM
