1. growlor's Avatar
    This is a really wierd one: I just bought a G4 yesterday. I had it charged from being connected either via PC or a spare charger while performing all the work I did on de-bloating, transferring files, etc, but as I have always done, I plugged it in at the nightstand next to my bed before going to sleep and the phone told me it was not compatible with the charger and charging would be disabled to protect the phone (this was with the cable and charger provided with the phone, not some generic one!)
    So I did some troubleshooting and found:
    The cable and charger combo worked fine with my old phone (an HTC Rezound.) The cable worked fine with the G4 when plugged into my Rezound's charger. The LG charger worked fine when using a generic cable.
    Is there some special feature of this cable and charger combo (like fastcharging) that might be malfunctioning due to me disabling what appeared to be bloatware apps? If not that any other ideas?
    07-27-2015 10:14 PM
  2. RedOctobyr's Avatar
    Mine just did this again this morning. The LG cable was not fully pushed into the charger. I'd suspect a connection issue before something with software.
    07-27-2015 10:28 PM
  1. Google Keyboard's autocorrect doesn't work in Chrome
    By JM22508 in forum Android Apps
    Last Post: 09-13-2015, 07:33 AM
  2. Can I use a Gear S and Gear 2 Neo with my phone?
    By MedicD in forum Samsung Gear S
    Last Post: 08-13-2015, 10:22 AM
  3. Why does my browser Google search list shows from the begining?
    Last Post: 07-27-2015, 10:13 PM
  4. Anybody streaming the event using cardboard?
    By msm0511 in forum OnePlus 2
    Last Post: 07-27-2015, 10:10 PM
  5. How do i update my samsung tab 4 to the latest version?
    Last Post: 07-27-2015, 09:47 PM
