Hi all,
Ive just purchased a "genuine" replacement battery for my LG G4 and when I insert the battery nothing happens.
There's no indication that any battery is inserted and even after leaving it charging (by lead) for an hour there's still no life and I can power it up.
Seller sent a replacement and that's exactly the same.
After closer inspection the only difference is the part number of the battery.
Original is
EAC62818401
Replacement is
EAC62818406
So, is it genuine and if so why doesn't is work in my UK LG G4?
Regards
Alun
Original is
EAC62818401
Replacement is
EAC62818406
Regards
Alun
