1. RocketFoot's Avatar
    I really like the LGG4 double tap to wake feature but it doesn't seem to work with Nova Prime. Any 3rd party launchers that support double tap to wake? Maybe an app to add to Nova?
    Sent from my LG-G4 using Tapatalk...
    08-16-2015 02:12 PM
  2. JayWill's Avatar
    Yeah, download the app Screen Off then set that app for the double tap gesture in Nova.
    08-16-2015 02:29 PM
  3. Kr0m's Avatar
    Hmm, it works fine on mine with Nova Prime... It's just the double tap to screen off is different for me .
    Sent from my LG-H812 using Tapatalk
    08-16-2015 03:24 PM
  4. iresq's Avatar
    Works on Apex.
    G4
    08-16-2015 03:29 PM
  5. gendo667's Avatar
    Works on Google Now too.
    08-16-2015 03:40 PM
  6. JayWill's Avatar
    Oh, I misread and thought he meant double tap to sleep. Yeah wake should work on any launcher.
    By the way, double tap to sleep works on Nova without another app if you tap the status bar. I prefer anywhere on the screen though so I use the Screen Off app when I run Nova.
    sswitzer likes this.
    08-16-2015 06:08 PM
  7. STiK's Avatar
    Sleep apps work great if you aren't using trusted devices.
    08-16-2015 07:47 PM
  8. anon(464338)'s Avatar
    Same with Apex. Should work on any launchers with gestures.
    08-16-2015 09:01 PM
  9. greydarrah's Avatar
    Double tap to wake works fine in Nova Prime (no special settings needed). To put to sleep, just double tap the notification bar (no special settings needed).
    RocketFoot and sswitzer like this.
    08-17-2015 11:39 AM
  10. RocketFoot's Avatar
    I finnaly made the switch to Nova Prime and double tap to wake does indeed work fine. So does double tap status bar to sleep but the status bar is high up on the phone and kinda hard to double tap one handed on the move so I found this bit of info on Reddit:
    Things you will need:
    Nova Prime
    Screen Off and Lock https://play.google.com/store/apps/d...nofflock&hl=en
    Go to Nova settings> Gestures and buttons > Double tap > Shortcuts Tab > Activities
    From there find screen off and lock and select 'screen off' (mainhelper)
    Thats it! Double tap on a blank area on your home screen to turn screen off, it works instantly.
    I tried it and it works great! Also added a cool TV off animation when the screen locks!
    08-19-2015 06:16 AM
  11. chyeo1979's Avatar
    But when using this method, it will lock your phone immediately. So it will render your smart unlock useless (if you are using it).
    08-19-2015 08:35 AM
  12. RocketFoot's Avatar
    I'm not using smart lock at the moment...what are the benefits of smart lock?
    08-19-2015 08:42 AM
  13. Suntan's Avatar
    FWIW, I also set up the "home" button to activate a Screen Off app when on the default page. That way two taps of the home button return the phone to the home screen and turn it off at the same time.
    08-19-2015 10:34 AM
  14. greydarrah's Avatar
    I was going to try this gesture shortcut, but under Activities, I do not see anything listed that resembles "screen off and lock," or "screen off," nor do I see anything related to "mainhelper" (or have any idea what that is). I will confess to having my lock screen settings set to None on my phone, so maybe options don't show up for me.
    08-19-2015 02:23 PM
  15. RocketFoot's Avatar
    You have to have Nova Prime (paid version) and Screen Off & Lock apps installed. Gestures won't work on free Nova.
    08-19-2015 02:31 PM
  16. greydarrah's Avatar
    I have Nova Prime. I guess it wont show a "screen off" option if you have your phone's lock screen set to "None."
    08-19-2015 02:34 PM
  17. Suntan's Avatar
    I have lock settings set to "None" too. The "screen off" people are talking about is a separate app that you download from google play.
    greydarrah likes this.
    08-19-2015 07:38 PM
  18. Jack Langiano's Avatar
    Using Nova Prime here with my Sprint G4 and works perfectly. Your Nova launcher isn't the problem.
    08-20-2015 08:02 AM
  1. Why doesn't a keyboard come up to type my password?
    By Sally Johnson2 in forum Ask a Question
    Last Post: 08-16-2015, 07:03 PM
  2. What is the easiest way to root my Moto C 2013 Android 5.1?
    By XboxOff in forum Legacy Android & Other OS's
    Last Post: 08-16-2015, 04:46 PM
  3. Replies: 1
    Last Post: 08-16-2015, 04:43 PM
  4. How can I root my Samsung Galaxy S3?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 08-16-2015, 01:46 PM
