Will the G Edge be LG’s answer to Samsung’s Galaxy S6 Edge? | AndroidAuthority
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
It wouldn't surprise me. LG loves to compete with Samsung and borrows a lot of ideas from them to use in their own phones.
rdt595
303
You mean like removable battery and storage?... Ummm... Wait....
Posted with LG G4 via the Android Central App
CPEjr
Active member
May 12, 2015
38
I'm sure LG will probably make this "Edge" phone, but I kind of wish they wouldn't. The G Flex's design is better in almost every way. They should work on that and market it like Samsung does with their S6 Edge. LG should make their own mark and not copy Samsung in their design AND name. Bad move, IMO.
Posted from one of my many Android devices.
RedOctobyr
511
Honest question- what was the Flex about? I've heard about it, and looking like a banana, but I really don't know what it was trying for.
D13H4RD2L1V3
Retired Moderator
Sep 4, 2013
4,407
It's a phone that's supposed to curve to your chin when you're making calls and also is designed to "flex", as in, becoming totally flat without any damage whatsoever.
It's a cool phone but one that has some compromises. The OG G Flex had a 720p display while the G Flex 2 had a toasty Snapdragon 810 and sluggish UI.
I personally find it cooler than the Samsung Edge phones mainly due to its ability to flex, but it's not good enough for mainstream use, I'm afraid. Hope the G Flex 3 nails every point down.
CPEjr
Active member
May 12, 2015
38
IMO, it was just LG showing off what they're capable of doing. But as the comment after yours had stated, it does curve to your face nicely while on calls as well as fit perfectly in your back pocket. It also feels awesome in the hand, especially compared to the "Edge" phone(s). Lastly, it literally flexes and can lay completely flat and no damage whatsoever will occur. It really is an impressive device in theory and in construction.
m1000
