1. rdt595's Avatar
    08-21-2015 04:36 PM
  2. UJ95x's Avatar
    It wouldn't surprise me. LG loves to compete with Samsung and borrows a lot of ideas from them to use in their own phones.
    08-21-2015 04:48 PM
  3. muckrakerX's Avatar
    Yeah, like the rear power and volume buttons... Oh wait.
    08-21-2015 05:20 PM
  4. rdt595's Avatar
    You mean like removable battery and storage?... Ummm... Wait....
    Posted with LG G4 via the Android Central App
    08-21-2015 05:32 PM
  5. CPEjr's Avatar
    I'm sure LG will probably make this "Edge" phone, but I kind of wish they wouldn't. The G Flex's design is better in almost every way. They should work on that and market it like Samsung does with their S6 Edge. LG should make their own mark and not copy Samsung in their design AND name. Bad move, IMO.
    Posted from one of my many Android devices.
    08-21-2015 05:54 PM
  6. RedOctobyr's Avatar
    Honest question- what was the Flex about? I've heard about it, and looking like a banana, but I really don't know what it was trying for.
    08-21-2015 07:35 PM
  7. D13H4RD2L1V3's Avatar
    It's a phone that's supposed to curve to your chin when you're making calls and also is designed to "flex", as in, becoming totally flat without any damage whatsoever.
    It's a cool phone but one that has some compromises. The OG G Flex had a 720p display while the G Flex 2 had a toasty Snapdragon 810 and sluggish UI.
    I personally find it cooler than the Samsung Edge phones mainly due to its ability to flex, but it's not good enough for mainstream use, I'm afraid. Hope the G Flex 3 nails every point down.
    08-22-2015 01:29 AM
  8. erwaso's Avatar
    I lol'd
    a22matic likes this.
    08-22-2015 09:04 AM
  9. CPEjr's Avatar
    IMO, it was just LG showing off what they're capable of doing. But as the comment after yours had stated, it does curve to your face nicely while on calls as well as fit perfectly in your back pocket. It also feels awesome in the hand, especially compared to the "Edge" phone(s). Lastly, it literally flexes and can lay completely flat and no damage whatsoever will occur. It really is an impressive device in theory and in construction.
    08-22-2015 09:43 PM
  1. Galaxy Note 4 to the Galaxy S6 Edge Plus?
    By Android Wheatron in forum Samsung Galaxy S6 edge+
    Last Post: 08-26-2015, 06:53 AM
  2. Replies: 7
    Last Post: 08-22-2015, 01:20 PM
  3. Why are the numbers on my home screen becoming white squares?
    Last Post: 08-22-2015, 01:54 AM
  4. How do you connect a Droid Maxx to a cable take pole. oid?
    By AC Question in forum Motorola Droid MAXX
    Last Post: 08-22-2015, 01:53 AM
  5. How to remove "AT&T Remote Support" on Galaxy Note 5?
    Last Post: 08-21-2015, 03:57 PM
