Got the ZeroLemon 8500 mah battery omg its a brick. Gonna put it through its paces today. Started 6am. Will keep y'all posted.
Printable View
1030. 93%
1314. 79%
How thick is the case? Can you post pics?
1450 64%
My pics won't do it justice it's pretty hefty but it feels good in the hand the pics on zerolemon website shows its girth better than any pic I could take. Hopefully they will come out with a better case than the current one like they did with my galaxy s4
1646 53%
Can you post more screen shots? SOT, etc.
Got mine yesterday as well. See attached.
2107. 44%
Wow, not bad at all
Thanks for the info
2144 hrs. 40%
What's the screen on time?
Please test if battery capacity is accurately read all the way to shutting down, or if it lingers at 3% for hours or something.
Thanks!
Over 26hrs for me, and still over 50% charge left.
Still holding strong. I even used the GPS for an hour trip, both ways. The only issue that I found was that it caused the phone to overheat during GPS use. And don't forget, no NFC with this battery.
But you charged?
No, I did shut it down for an hour to cool off.
Looks like a charge?
Dunno. But to get back on track, it shut down at around 3am. So that was a total of 45 hours and 7 hours of screen on time. It overheated using the GPS. It doesn't offer NFC support. It's big, bulky, and ugly. That being said, it did offer a great amount of use before it died. This is a great option if you know that you won't be near a charger for awhile. Overall it's worth it if you frequently participate in activities without a charging option.
Maybe it's self charging.
G4
