A
AC Question
LG G4 qi qireless charging stopped working
I added the wireless charging antenna NeWisdom® from amazon and it worked well with my different qi chargers including Itian A6 Qi Three Coils Wireless Charging Pad with 5V from amazon for couple of months.
Last week i used the fast charger that comes with a nexus 6 and since then wireless charging stopped working for me ( i tried multiple wireless chargers CHOE UPGRADED Qi Wireless Charger Charging Pad from amazon). Even worse using the cable directly from the wireless charger i referred above does not work ( other charger cables i have seem to work ok when i plug them in).
Is it possible that once you use a fast charger you cannot use qi wireless or any other chargers that are not as powerful? how can i fix it? could factory reset help?
PS : i tried realigning the antenna sticker but nothing works!
