1. op4500's Avatar
    Every time I plug in an aux cord my volume drops to around 2/3. Can't seem to get it to stay at max. Does anybody have a solution for this? It's really annoying because I use it in my car all the time.
    10-18-2015 07:45 PM
  2. RandyOhio's Avatar
    Try an application called Volume Boost, that will increase volume when something is plugged into the headphones jack.
    10-18-2015 09:21 PM
  3. Mooncatt's Avatar
    Are you able to turn it back to full volume? Like you, I also use the headphone jack a lot to plug into my car stereo and I know Android started an annoying "we know what's best for you" nag where it'll reduce the headphone volume when you plug anything into it. Rumor has it that it has to do with some European regulation that made them do this, and it's to protect your ears. On every other phone I've had, I could turn the volume back up if I cleared the nag message. On one, it was tied to its own app that I could freeze once rooted. I'm still working on getting a G4, so I don't know if there is a solution to it on this phone.
    But I agree, it sucks. I listen mostly to podcasts, which seem to be notorious for being encoded at a low volume. Even with the phone volume at max, I sometimes I have to nearly max out the stereo volume to hear them clearly.
    10-19-2015 04:19 AM
  4. op4500's Avatar
    yeah I can turn it back up after the annoying popup goes away. My nexus 6 never did that so I figured it was an LG thing that could maybe be disabled.
    10-20-2015 12:59 AM
  1. Replies: 1
    Last Post: 10-19-2015, 03:40 AM
  2. Replies: 1
    Last Post: 10-18-2015, 09:09 PM
  3. How do I update AT&T HTC One X with wifi?
    By AC Question in forum HTC One X
    Last Post: 10-18-2015, 07:29 PM
  4. Replies: 1
    Last Post: 10-18-2015, 06:47 PM
  5. Replies: 0
    Last Post: 10-18-2015, 06:39 PM
