I have a lg g4. When you say a sentence and it doesnt pick up exactly what you said correctly, you are able to click on the word or words and 3 or 4 choices would pop up and you could click the correct word or phrase... My phone no longer does that. Also if you misspelled a word it used to work the same. Now all i get is the 2 to 3 choices in the bar right above the numbers, which doesnt even give any good options. Is there a setting that somehow unchecked itself that im not seeing? Ive looked through all my settings and restarted my phone numerous times. Also, just using the stock google / lg keyboard
Thanks in advance.
Thanks in advance.
