1. AC Question's Avatar
    LG G4, Android 5.1.
    Basically, I want to plug in a headphone jack and want to phone to not turn off it's earpiece. Hence still be able to hear from the phone and talk while plugged in.
    *more Info*
    Phone got run over by a CAR...BUT STILL WORKS! except... cracked screen and during calls the screen turns OFF!!! I can't use the screen, I can't use the dial pad, can't hangup, can't use other apps. The person on the other side has to hangup. Tried a lot things in settings but no luck. Thought it was the proximity sensor but proximity sensor works fine when I call my voice mail box: screen stays ON when help down and turns OFF when put next to my face. I found a hack, when connected to an audio device the screen doesn't do this, it acts normal. I can't always have a long wire plugged in and a Bluetooth headset drains CRAZY battery. I have a dummy audio jack: just the jack with no actual device on the other end. THE PHONE STAYS ON WITH IT! ...but I cant talk or hear anything because my phone turns OFF its own audio output when a jack is connected. Any suggestions and advice will be very appreciated.
    THANK YOU!
    03-11-2016 12:50 AM
  2. gavo360's Avatar
    app called soundabout might work well for you. I had a phone that had a fault on the headphone port and it always thought they were headphones plugged in so automatically disabled the earpiece and main speaker but soundabout app has quite a few options so was able to bypass the headphone jack and send sound to the other speakers.
    03-11-2016 02:04 PM
  1. Replies: 3
    Last Post: 03-13-2016, 04:55 AM
  2. How do I remove the sim card in my Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-12-2016, 12:19 AM
  3. How hot is too hot? [Moto X Pure Edition]
    By turbo93 in forum Moto X
    Last Post: 03-11-2016, 10:23 AM
  4. Google play not updating via wifi with Verizon phone?
    By wxman2003 in forum Samsung Galaxy S7 edge
    Last Post: 03-11-2016, 12:13 AM
  5. Why is my Samsung GTP3113 Tab is not starting up after reset setting?
    By AC Question in forum Samsung Galaxy Tab Pro 12.2
    Last Post: 03-10-2016, 11:47 PM
