1. ryanhark's Avatar
    Well I have been experiencing a faster drain on my battery(s) so I purchased a Hyperion 6000mah battery but it's larger and doesn't fit my protective otterbox. The back that came with the battery is cheap. I was wondering if there are any quality cases out the for this issue.
    05-26-2016 10:22 PM
  2. Gaurav Sag's Avatar
    I will suggest you MJP, This MJP battery will give a MASSIVE boost to your phone's life. Makes the phone a lot more beefy and a bit more heavy, but if you are a heavy user it is way more than worth it to try. The case/battery is flatter than the standard back of the G4 which makes it sit steady on table tops which I liked.
    The charging speed is about the same as the original battery but 2 X more because its 6000mAh. The charging temperature is around 23 degree C which is quite cool. I had even tested to see the battery will hold charges.I fully charged the battery and left it unused for 3 days. Then put it on G4 and its still at 100%.
    05-26-2016 11:45 PM
  1. Battery Life is ridiculous!
    By Richard Servello in forum Pixel C
    Last Post: 06-06-2016, 12:57 PM
  2. Replies: 1
    Last Post: 06-02-2016, 08:30 AM
  3. MLG Watch Urbane 2 LTE 6.0 Firmware
    By idle0095 in forum LG Watch Urbane 2nd Edition
    Last Post: 05-28-2016, 10:24 AM
  4. Replies: 1
    Last Post: 05-27-2016, 04:59 AM
  5. My LG Keyboard is failing, How do I fix it?
    Last Post: 05-26-2016, 09:55 PM
