1. Stylazation's Avatar
    As the topic says, the glance view and double tap stopped working after shutting down there phone and leaving it in charge. Turned back on noticed that some features like glance view, double tap to wake up, vibrate on tap wouldn't work. Fixes vibrate on tap by turning off and on again, recalibrated phone still the glance view and double tap to wake up isn't working with screen time out being 1 minute and it dims and turns off in seconds.
    Any one know this problem or a fix may be. Kindly put your effort and thoughts I to the topic thank you.
    06-04-2016 10:17 PM
  2. shadavis08's Avatar
    Did your phone update on you? Sometimes an update will change settings.
    06-06-2016 01:25 PM
  3. shadavis08's Avatar
    Or do you use an launcher different from LGs launcher? If so did it get an update?
    06-06-2016 01:31 PM
  4. Stylazation's Avatar
    Fix
    1. Download this app
    https://play.google.com/store/apps/d....quickshortcut
    2. Open app and select normal search
    3. Search with keywork "knock" and add that shortcut.
    Then open that shortcut and make sure that knock on is turned on.
    07-24-2016 05:11 PM
  5. Stylazation's Avatar
    Yes, the while phone changed settings most of the features turned on were turned off. It felt like being on stock. But I did not accept it allow any update on my smartphone. That's weird really.
    07-24-2016 05:12 PM
  1. Replies: 1
    Last Post: 06-06-2016, 08:26 AM
  2. GET: SD card tap here to tranfer message after update
    Last Post: 06-06-2016, 08:15 AM
  3. Replies: 1
    Last Post: 06-06-2016, 07:56 AM
  4. Did my simple share get viewed
    Last Post: 06-06-2016, 07:54 AM
  5. Messenger app not showing pop up notifications
    Last Post: 06-04-2016, 10:15 PM
