1. Jarod Boyd's Avatar
    I just updated my G4 to marshmallow yesterday on full charge, and after about an hour of normal use, it was at 5%. Before the update, it would last at least 5 hours of moderate use. Is anyone else experiencing this, or am I just going to have to trade it in?
    06-26-2016 03:03 PM
  2. B. Diddy's Avatar
    Moved to the G4 forum.
    It may be helpful to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    06-26-2016 08:04 PM
  1. Replies: 3
    Last Post: 06-27-2016, 07:25 AM
  2. Replies: 2
    Last Post: 06-26-2016, 10:50 PM
  3. LG G3 Bootloop?
    By AC Question in forum LG G3
    Last Post: 06-26-2016, 02:55 PM
  4. LG G3 Bootloop?
  5. Replies: 1
    Last Post: 06-26-2016, 02:50 PM
