LG g4 Screen Freeze Problem
A
AC Question
Hello,
I'm having a constant problem with the screen freezing on my LG g4 h815 shortly after it is loaded on the main menu, i can be on any screen when it happens. I've tried a soft reset but when i try the volume down and power trick to go into the recovery mode, it just boots the vodaphone sign and goes straight in safe mode.
can any one help.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
And then you may have to reflash the ROM - or some hardware in the phone may be failing.
(For backing up, see Backing up an Android Device. You don't have to back up system apps - they're on the ROM or the new phone if you have to go either of those routes.)
fallingOutOfLoveWfithTech
