1. AC Question's Avatar
    Hello,
    I'm having a constant problem with the screen freezing on my LG g4 h815 shortly after it is loaded on the main menu, i can be on any screen when it happens. I've tried a soft reset but when i try the volume down and power trick to go into the recovery mode, it just boots the vodaphone sign and goes straight in safe mode.
    can any one help.
    07-17-2017 07:45 AM
  2. belodion's Avatar
    First, do a full backup while you still can, unless you have already.
    07-17-2017 08:51 AM
  3. Rukbat's Avatar
    And then you may have to reflash the ROM - or some hardware in the phone may be failing.
    (For backing up, see Backing up an Android Device. You don't have to back up system apps - they're on the ROM or the new phone if you have to go either of those routes.)
    07-17-2017 01:31 PM
  1. Lg V20 Bluetooth problems
    By Kyle Workman in forum LG V20
    Last Post: 12-05-2017, 12:08 AM
  2. Replies: 2
    Last Post: 10-15-2017, 09:47 PM
  3. Replies: 7
    Last Post: 07-19-2017, 09:24 AM
  4. Replies: 2
    Last Post: 07-17-2017, 02:44 PM
  5. Replies: 1
    Last Post: 07-17-2017, 08:24 AM
