I've had this problem for over a few months now and I don't know what to do, I'm not able to buy a new phone so I need this fixed if it's possible. It usually happens when I am using mobile data and a heavier app, for an example, if I try using snapchat while on mobile data, my phone will just turn off and it will try to start up again on its own, sometimes it does and it jumps from let's say 80% to 2% and I have to charge it. Sometimes it doesn't turn back on until I plug it onto a charger and then it starts up again, usually always showing a vastly different battery percentage than it was before. Sometimes it doesn't even involve mobile data and heavy apps, yesterday I was connected to a Wi-Fi network and texting someone, suddenly the battery dropped from around 50% to 2% and the battery icon had an x on it, I put it to charge but it died nonetheless and suddenly showed me it had 44%. I really don't know what to do, I hope maybe replacing the battery would do, it's just annoying to have your phone die at random times. Thanks in advance.
