nikos geros
Re: LG G4 start up - optimizing app 1 of 1 10 mintes
Uninstaling the app "ZEDGE" should do the job thanks a lot
Yeah, that app gave me the same super annoying problem some weeks/months back. Deleted apps one by one to figure it out. However, that app (if updated to current version) does NOT have that issue any longer.I had exactly the same problem. I found the solution on the web. The culprit turned out to be an app called "localcast for chromecast". If you have it, erase it and your problem will probably be over. It worked for me.
Let us know if it worked for you!
For future reference, yes, there is a way to see what your most recently installed and/or updated apps are. Go to the Play Store, click "my apps", and then click the sort by icon and change it to "last updated". Def helped me figure out this issue when I had it.Android Is Starting- "Optimizing", 1 0f 3. Removed ZEDGE. Now I get "Optimizing", 1 0f 2. Is there a way of looking at your apps install dates and back tracking to delete the most recent until you fix the problem??? BTW: thanks to all of you who pointed out ZEDGE, which I have had several yrs.
Had this problem too, and for me it was MyFitnessPal that caused it.
Uninstalled it, and phone boots fine.
Interestingly, reinstalled it, and it took ages to install, but phone still starts quickly now, even with it installed!
Having the same issue with MyFitnessPal. Removed it and the problem was fixed, put it back on from Google Play and it took an age to install, like half hour but came back fine. Had to swap battery over and it was back to optimising app again :'(
Every time I reboot my LG G4 I get the Android is starting. Optimizing app 1 of 1... and takes about 15 minutes to finish each time.
I've tried booting into recovery mode to wipe the partition cache, but the phone won't seem to boot into recovery mode by Holding the Power button and volume down buttons on boot. It ignores it.
I've also tried using the adb reboot-bootloader command but it just reboots as usual with the only difference is that it displays a message saying: "Select enable OEM in the settings". Not sure what that means.
I have never rooted this phone.
I have had the same issue on my lg v10 for about a week. I removed the Zedge app and it fixed the problem. I had the app for over a year without any problems, so didn't suspect that it was causing the issue until I found this forum.
How do I identify this Zedge app that is causing this problems, I have almost deleted all my apps yet the same issues occur
Likewise have been having this issue for the past week. Never even heard of Zedge, and don't have the Localcast app either. My G4 bootlooped about 14 months ago and was fixed by LG (FOC) and thought it had happened again, but it does eventually boot.
Probably unrelated but Fast Charging no longer works, only standard (slow) speed works.
