1. Sugarmoon88's Avatar
    Hi ive just received my lg g5 and when ive pulled the module out the battery is quite wobbly i can move it forward and backwards a little bit, its not solid in the module, is this right or have i got a dodgy one? Thanks
    04-13-2016 02:23 PM
  2. ninjataint's Avatar
    On mine, it wobbles slightly if I hold the chin and shake it. I assumed is by design for getting it off. It certainly doesn't come off without a fight and I don't hear any wobble in the phone. I assume the phone itself prevents that.
    04-14-2016 12:05 AM
  3. Mike Dee's Avatar
    Once it's inside it's seated and you should have no worries.
    04-14-2016 05:44 AM
  4. H3aTeRzz's Avatar
    This was the only thing I had questions about. I love the idea of the removable battery, but questioned its solidness, based on how its removed/replaced.
    04-29-2016 09:35 AM
  5. the tall guy's Avatar
    When you remove the module, the battery can wobble if you shake it, but that's to be expected as it's a tall battery secured only at the base. Once it's in the phone it doesn't move and it's secure. It's also very difficult to actually remove the battery from the module - it takes a few turns to get it off.
    I actually forget that the phone has a removable base, I think I've only ever removed it twice.
    JanuarJaguar likes this.
    05-04-2016 05:36 AM
  1. G5 crashing problems.
    By ballonem in forum LG G5
    Last Post: 11-03-2017, 10:34 AM
  2. Replies: 15
    Last Post: 04-29-2016, 03:46 AM
  3. How do I clear/clean ram on a LG L31l?
    By AC Question in forum LG L Series III
    Last Post: 04-17-2016, 06:08 PM
  4. Replies: 2
    Last Post: 04-13-2016, 02:11 PM
  5. Replies: 0
    Last Post: 04-13-2016, 01:42 PM
