1. ricks's Avatar
    I'm looking for a belt pouch(case) for my G5. Wanting one that will fit with a thin case in the phone. Anyone know of a good one? There's a bunch on ebay and Amazon but not sure which one to get...
    08-09-2016 07:35 PM
  2. anon(9983233)'s Avatar
    If I had to choose something rugged and very stylish for the LG G5 I'd say the Subcase holster
    Source: LG G5 UB Pro | LG G5 Case | SUPCASE
    08-10-2016 07:18 AM
  3. ricks's Avatar
    I meant a leather type pouch with magnetic closer.
    08-10-2016 09:16 AM
  4. muckrakerX's Avatar
    You and I must be the only two people on the planet who use leather belt pouches!
    ricks likes this.
    08-10-2016 12:00 PM
  5. muckrakerX's Avatar
    I like the Cellet brand pouches. For anything not Apple or Sammy, you'll probably have to measure the outside dimensions of your phone /case, and look for a pouch with inside dimensions just slightly larger.
    ricks likes this.
    08-10-2016 12:04 PM
  6. anon(9983233)'s Avatar
    Nice.. love the trick questions.. by no means did you suggest any case constructed of leather as mentioned via your quote above.. thus I answered accordingly.
    08-10-2016 01:28 PM
  7. ricks's Avatar
    What does "pouch" mean to you???
    08-10-2016 01:42 PM
  8. sydneycooper1979's Avatar
    https://www.amazon.com/Leather-Tribu...cUvbUpU5314263
    Is this what you are looking for? Amazon has quite a few.
    ricks likes this.
    08-10-2016 01:44 PM
  9. ricks's Avatar
    Yes, thank you. Now I need to figure out if I should get horizontal or vertical??? I can see the needs for getting both styles for certain days.
    My biggest concern with these is finding ones where the phone will fit nicely and not be too loose or too tight.
    08-10-2016 01:49 PM
  10. sydneycooper1979's Avatar
    Yes, they both can definitely come in handy. Here's a vertical pouch.
    https://www.amazon.com/Kingsource-Po...cUvbUpU5314280
    ricks likes this.
    08-10-2016 01:50 PM
  11. Mike Dee's Avatar
    I once met a kangaroo with a pouch
    ricks likes this.
    08-10-2016 02:00 PM
  12. ricks's Avatar
    I wonder if it smells in there??? LoL
    I was thinking that the G5 is about the same size as the G4. Could help with more choices???
    08-10-2016 02:25 PM
  1. Any Cases With More Grip Than the Spigen [Thin Fit] Exact-Fit?
    By Bold9930 in forum Samsung Galaxy S7 Cases & Accessories
    Last Post: 10-17-2016, 01:29 PM
  2. Best Transparent Kickstand Case?
    By recDNA in forum Samsung Galaxy Note 7 Cases & Accessories
    Last Post: 08-16-2016, 09:50 AM
  3. Anyone know of a good belt pouch for the LG G5?
    Last Post: 08-09-2016, 07:25 PM
  4. R-just gundam case for note 4 blocking gps signal.
    Last Post: 08-09-2016, 07:21 PM
  5. NO Case for Moto Z with Mods
    Last Post: 08-09-2016, 12:12 PM
