1. Umzling's Avatar
    Since getting Verizon Nougat upgrade the only change I see is this battery icon on the lock screen which drives me crazy. I use Nova launcher. Anybody know how to get rid of this?
    Thanks.
    Attached Thumbnails How to remove battery icon from lock screen?-lock-screen.jpg
    12-19-2016 11:57 AM
  2. Sam_Gs7's Avatar
    The quickest answer could be provided by your Phone carrier..
    Contact them by phone-onLine or visited one of its Stores
    12-19-2016 12:07 PM
  3. mamalk's Avatar
    I was just about to post this too haha
    Updated today and seeing battery display on lock screen drives me bonkers
    12-19-2016 08:55 PM
  4. Umzling's Avatar
    Went to Verizon today. They cannot remove it. They suggested writing to LG, which I guess is the next step.
    12-20-2016 01:57 PM
  5. Umzling's Avatar
    I wrote to LG yesterday. I just received the response.
    The battery icon cannot be removed as it part of the update to Android 7.0, Nougat.
    To remove the message about slow charging, they suggest a factory reset as a possible workaround. Is this a cure? They don't say for sure.
    I am not pleased. I'm not interested in starting over again.
    12-22-2016 06:25 PM
  6. Sam_Gs7's Avatar
    I guess you've to reconsider the Unlikeable battery icon in the
    unlocked screen..Samsung have similar feature called
    AoD=Always on display it shows >>Date & Time
    plus battery icon and 90% of users approved
    The choices to remove a slower charging is the Factory reset
    and to fix the battery icon-Switch to different phone..is upto You.?
    Unfortunately as in our PC's-Not always is customized as We please
    12-22-2016 08:19 PM
  1. How to delete Others Files from storage device?? Please help
    Last Post: 04-05-2018, 06:37 AM
  2. asus zenfone won't connect to cell service but will wifi
    Last Post: 12-19-2016, 11:21 AM
  3. Replies: 1
    Last Post: 12-19-2016, 11:06 AM
  4. Replies: 0
    Last Post: 12-19-2016, 11:03 AM
  5. Hi, my android screen appeared blue and switched off
    Last Post: 12-19-2016, 11:00 AM
