1. AC Question's Avatar
    Not sure they ever worked, as the phone went straight to Nougat update upon connecting it to WiFi, but I am not getting lock screen notifications, nor LED, when texts come through. I've troubleshooted to death to no avail.
    03-13-2017 10:00 PM
  2. Crabby Abie The Queen T-Flo's Avatar
    Hi. Did you check settings notifications?
    03-14-2017 12:41 PM
  3. Matthew Barcellos's Avatar
    Yes, I've checked everything. The notifications work when I install a separate app, but I'm a minimalist at my core, and believe that such a simple feature should work without the need to install a separate app.
    04-25-2017 03:07 PM
  1. Note 5 lock screen problem
    Last Post: 03-13-2017, 09:10 PM
  2. Replies: 1
    Last Post: 03-13-2017, 09:08 PM
  3. Download problems Note 4
    Last Post: 03-13-2017, 07:34 PM
  4. Why won't my Samsung Galaxy Note 5 screen turn on?
    Last Post: 03-13-2017, 07:17 PM
  5. Should I have bluetooth 5.0.36 and 6.0.1 on my lg k3
    Last Post: 03-13-2017, 06:33 PM
