LG G5 Main rear camera is not focusing (blurry pictures)
Hello:
I have a LG G5 (H831 running Android 7.0). Cameras were all working fine since new but now the main rear camera (non-wide angle) will not focus. I have searched on the web and there is no clear answer what the issue may be. Several LG G5 owners have the same issue. Even replacing the camera for some has not helped.
Things that I done so far (none have helped):
1. LG Camera App
- Forced closed
- Cleared memory
- Cleared Cache
- Tested manual focus. It does nothing. Note the sound heard during manual focus changes are App generated and not the actual auto-focus motor (turn volume down and they go away).
- Camera is in-focus only at about 1 foot (30 cm).
- Tested that the auto-focus led is working by looking at it with a camera – I can see it flashing – not sure if that means it is working 100%. You can also test this by doing a video with the LG G5 camera pointed at a mirror (couple feet away).
2. Other Camera Apps
- They don’t work either.
3. Phone
- Phone reset (do backup and watch out for Google Authenticator requirement using the same phone being reset – get list of printed codes to use)
- Gently tapped phone – okay maybe more than gently (to see if mechanism unsticks)
Questions:
- Is the focus mechanism built into the camera?
- Would the only other suspect hardware item be the auto-focus LED flash assembly?
Current options
- Even though others have indicated that a camera replacement didn’t work, I will probably have to order the camera and LED board. (warranty has expired)
- Any other options suggested here.
Hello:
1. LG Camera App
- Forced closed
- Cleared memory
- Cleared Cache
3. Phone
Questions:
Current options
