1. Berserk77's Avatar
    Hello,
    My LG G5 battery is not charging properly while plugged in and using the phone at the same time. The connected icon is displayed but the battery percentage keeps going down.
    I use LG original usb cable and 2.4A charger. So i guess my charger and cable shouldn't be the issues.
    This is not normal for Android phones although it is recommended to leave the phone untouched while charging.
    Do you know any battery application to at least make the battery percentage not going down? I currently use greenify to maximise the number of background apps to be hibernated (non rooted).
    Thanks.
    01-10-2018 11:26 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's still worth trying a different charging cable and plug. If something is wrong with the one you're using, the phone might be charging as if it were plugged into a computer USB port (which charges very slowly), instead of recognizing that it's plugged into an AC wall outlet. If you plug a device into a computer USB port, the rate of charge can often be outpaced by the rate of battery usage, if you're actively using the phone.
    01-10-2018 11:12 PM
  1. Notification Sounds Not Going Through Bluetooth
    By BriniaSona in forum Samsung Galaxy Note 8
    Last Post: 01-11-2018, 08:34 AM
  2. Why is Google pixel sound goes silent?
    Last Post: 01-10-2018, 11:16 PM
  3. can't get into lg m150 wants a synched account
    Last Post: 01-10-2018, 12:05 PM
  4. Replies: 1
    Last Post: 01-10-2018, 11:05 AM
  5. LG L90 WiFi can't turn on
    Last Post: 01-10-2018, 11:00 AM
