    Hello,
    So my LG G5 won't start right now, when I charge it, the LED will flash red lights and shows the battery at 0 percentage. Been charging for 12 hours. I thought the battery could be the problem. Borrow my friend's G5 Battery, tried it and still the same.
    Anyone know how to fix this?
    Thanks
    07-05-2018 04:22 AM
  2. Rukbat's Avatar
    The charger (the parts in the phone - what you plug into the wall is just a power supply) has at least one bad part. You need to find a repair shop that will replace parts. (Most just replace the motherboard, and that's a lot more expensive.) (And, of course, they have to be able to figure out which parts are bad, which is why most of them won't replace parts - they're parts-replacers, not technicians, so the "part" they know is bad is the motherboard.)
    07-05-2018 01:30 PM
  3. Mike Dee's Avatar
    It could be a problem with the lower module but know way of telling unless you can find someone with a module that works
    07-05-2018 01:38 PM
  4. Greedog's Avatar
    Did you resolve this issue?
    08-19-2018 08:06 AM
  1. Replies: 3
    Last Post: 07-12-2018, 05:37 PM
  2. Replies: 2
    Last Post: 07-05-2018, 11:50 PM
  3. downloaded apps wont install
    Last Post: 07-05-2018, 03:39 PM
  4. Why is my battery percentage going down while charging?
    Last Post: 07-05-2018, 12:22 PM
  5. keyboard typing speed LG V30 lag
    By Dajoen88 in forum LG V30
    Last Post: 07-05-2018, 11:56 AM
